20 Most Recent
Brother MFC-8640D Printer Questions & Answers
Machine error 7a on brother mfc8640d
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
For more information and help........
http://www.fixya.com/support/t5660619-7a_error
9/22/2010 4:53:02 AM •
Brother...
Answered
on Sep 22, 2010
How can I scan files to pdf using Brother
You will need to open the control center program which is installed when you install the printer on your computer.
Start,
all
programs, Brother, control center. Click on configuration then scan
then file (or which ever you normally scan to). There are two tabs at
the top, change the file type at top of each tab to pdf and press ok.
7/3/2010 1:02:38 PM •
Brother...
Answered
on Jul 03, 2010
Brother Scanner, scans the page but prints black and vertical
I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
12/27/2009 11:35:17 AM •
Brother...
Answered
on Dec 27, 2009
I have the Fuser Open message
This is most probably a failure in the Fuser assembly heater element.
The fuser is the unit in the back of the machine where the hot rollers sit.
If you are not competant at fixing electronic equipment then you will need a service technician to fix this. High voltages are present at the fuser.
12/22/2009 12:40:08 AM •
Brother...
Answered
on Dec 22, 2009
Prints more toward grey than black.
Here is the users manual:
http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=mfc8640d_us&type2=5&flang=English&dlid=
8/12/2009 9:40:15 PM •
Brother...
Answered
on Aug 12, 2009
I have a Brother 8640D
if its going through the drum, then its stopping at the fuser area.
you have a broken gear on the fuser. the fuser will need to be repaired. approx. cost for fuser repair will be about $75.00
6/26/2009 4:59:45 AM •
Brother...
Answered
on Jun 26, 2009
I have brother MFC-8640D printer
From the manufacturer website! :-)
http://www.brother.com/html/download/index.htm
go to the search box and put your model no. in....
6/14/2009 7:07:41 AM •
Brother...
Answered
on Jun 14, 2009
Vertical line on Brothe MFC 8460N
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
PREM
3/22/2009 8:33:17 PM •
Brother...
Answered
on Mar 22, 2009
