20 Most Recent Abit NF-M2S Motherboard Questions & Answers
Abit is no longer around, good luck on finding one
Abit NF-M2S... | Answered on Dec 02, 2014
I am not sure if you have tried this, but take one stick of ram put it in the first slot. Try to boot if it beeps or not, power down and move to the next slot with the same chip (we are assuming this is a good ram chip). Repeat for every slot on the computer. If you have 1 or 2 slots that beep and the rest do not; bad slot on the mother board. If all slots beep, try a different chip (bad ram??). If no slots beep, repeat steps with each individual ram chip (you could have just one or two bad and causing all the issues).
Hope this helps
Abit NF-M2S... | Answered on Mar 27, 2012
I bet you have SATA Hard drive? Your installing windows XP? Go into BIOS and change the SATA setting to act like IDE and it should install OK. Other wise you need a SATA driver disk for when you first install, use the F6 and insert floppy disk with SATA driver.
What version of Windows are you installing?
Abit NF-M2S... | Answered on Mar 02, 2011
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Abit NF-M2S... | Answered on Jul 12, 2010
unfortunately that is the problem. sooner or later it will just not boot up. If you are capable and want to get in to it, you can change the capacitors. if not look for a board. try ebay or pricewatch. they may still have one that would fit your processor. =)
Abit NF-M2S... | Answered on Jun 19, 2010
You a need a pair of identical memory modules must be placed in matching DIMM slots in order to to make it work. They need to be same mfg, everything.
Thanks Mark
Abit NF-M2S... | Answered on May 14, 2010
Sounds like memory. If you have more than one stick of memory, try using 1 stick at a time and see if it will boot.
Abit NF-M2S... | Answered on Mar 12, 2010
check ur motherboard there is one panel down is written
"panel or front panel"
now when u find these panel rest is simple u have to just see down this panel everything is written
Abit NF-M2S... | Answered on Mar 07, 2010
yes
Abit NF-M2S... | Answered on Feb 27, 2010
The beeps indicate that error is usually caused by hardware incompatibility or failure. More specifically check the following list:
You installed new hardware that is conflicting with old hardware.
There was a reecent electrical storm that caused a surge that damaged parts of the computer.
Try the following:
Remove new hardware.
Remove any disks or USB devices.
Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes.
Disconnect external devices.
If nothing appears to work then try removing the ram and installing a new module.
Abit NF-M2S... | Answered on Jan 28, 2010
You should have a seperate disc for the motherboard drivers. Did the motherboard crash or your system?
Abit NF-M2S... | Answered on Dec 04, 2009
There is no problem about that because my system here was all removable storage detected.its thesame (SATA) ..If try to safely remove that you cannot remove because it was use by the system so don't worry about that.
I encoutered that problem 35 times already.
Hey for this problem most of the times user thinks that motherboard got corrupt.
but try this first. use your Operating system CD and repair it
use command chkdsk for repairing.
If not then format the system
Abit NF-M2S... | Answered on Dec 01, 2009
Installed on this board a few days ago and worked fine.
Realtek RTL8169-8110 Family Gigabit Ethernet NIC
Driver Provider: Realtek Semiconductor Corp.
Driver Date: 7/17/2008
Driver Version: 5.699.717.2008
Abit NF-M2S... | Answered on Apr 18, 2009
Try making a disk again - use a brand new disk and check it for errors.
Abit NF-M2S... | Answered on Mar 02, 2009
The model number for your Abit motherboard is incorrect (Abit doesn't list one with it). I think I might have found what you really have, though. If so, the power LED attaches to the opposite side of the speaker connector, which is next to another set of headers. You should see it notated as such on the MB, too.
Feel free to take a look at it, and see if it matches what you have:
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=6&category=5&subcategory=247&model=124&product_name=NF7-S+v2.0
Cheers
Abit NF-M2S... | Answered on Nov 13, 2008
Abit NF-M2S Motherboard Logo
32 questions posted
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Abit Computers & Internet
Most Popular Question
want connect power led amp hdd led
  • Computers & Internet
