20 Most Recent Beyond Micro (BM200MD3U28M) 500 GB USB 2.0 Hard Drive Questions & Answers
no go to an authorised vendor who can backup your data...
Beyond Micro... | Answered on Jan 06, 2011
Try connecting the Beyond Micro to another computer.
If the problem persists, it's the unit, not your copy of Windows XP, that is the problem.
Beyond Micro... | Answered on Nov 02, 2010
Sorry, the hard disk inside your external enclosure has suffered a mechanical failure and died. It's unfixable so take it out of the enclosure and replace it.
Beyond Micro... | Answered on Aug 19, 2010
Try downloading EASUS Partition manager http://www.partition-tool.com/. I have not used this with FAT formats but it works fine with NTFS, and allows you to alter partition sizes without losing data.
As far as I know it is only supported by Windows, so you may have to use a Windows machine to re-partition.
Beyond Micro... | Answered on Mar 09, 2010
The only thing to do is make sure you go through all Windows Updates. Then go to manufacturer's website and download Win 7 drivers. Then install via add new hardware. Sounds more like a USB driver issue...
Beyond Micro... | Answered on Dec 25, 2009
A clicking noise from a hard drive is a sign of a faulty hard drive.
That is why the computer does not see it.
The hard drive needs to be replaced.
Beyond Micro... | Answered on Oct 08, 2009
Just but a new USB drive enclosure like this:
https://www.amazon.com/AmazonBasics-3-5-inches-SATA-Drive-Enclosure/dp/B01MZC303G?psc=1&SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B01MZC303G
but make sure you get the right kind. 2.5" for laptop size or 3.5" for desktop size drives. FYI - It could also be that the power brick on your old hdd enclosue one went belly up. They are typically cheaply made switch mode power supplies from China. Check the voltage and see if you have abother with the same current capacity to try. Good luck!
Beyond Micro... | Answered on Feb 04, 2018
Hi , I can fix this issue, call me at 1-800-339-9634 , $ 30 is what I will charge. Harry
Beyond Micro... | Answered on Jun 14, 2017
Mine came with a "DVE Switching Adapter":
(Model: DVS-120A15FUS
Input: 100-240V ~ 50/60Hz 0.7A)
Output is +12V, 1.5 A
Diagram indicates that the outer shield is negative, I think.
Beyond Micro... | Answered on Dec 22, 2016
Hi!
You can find the original drivers for this drive on the manufacturer's website, here:
Chronos HD 337 U2 Driver New Win All
Hope this helps!
Beyond Micro... | Answered on Mar 12, 2016
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Beyond Micro... | Answered on Aug 25, 2010
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Beyond Micro... | Answered on Jul 07, 2009
Your Beyond Micro drive may have come with backup software. If it did then use it to create a backup of your PC. If not get a program from the web such as:
http://www.goodsync.com/howitworks.html
There are may others available for you to try out.
cheers
Beyond Micro... | Answered on Jun 16, 2008
Which email account ?
Erase Email Addresses in My Computer
Email addresses can be stored on a computer if you use email software, such as Microsoft Office Outlook and Yahoo Messenger Beta.
Deleting email addresses manually from these programs does not actually completely erase them from your computer.
To erase email addresses permanently, meaning that a hard drive recovery program will not be able to restore them if it is used, requires a process called formatting, which completely erases the information on a hard drive.
Click on the shortcut "My Computer," which you can locate on your desktop.
Right click "Local Disk (C:)" and select the "Format" option.
Change the "Allocation Size Unit" to "Default Allocation Size."
Click the "Start" button.
The email addresses, as well as the rest of the files on the hard drive, will now be erased.
Delete a Live Mail Email Address
Windows Live Mail is a part of the Windows Live suite of productivity and entertainment programs, and it is intended to be the new free email client for Windows beginning with Windows 7.
After trying Windows Live Mail, you may decide that you have added too many email addresses and that you would prefer to use the email client to check only one address.
Remove an email address from Windows Live Mail to reduce the clutter in your email inbox.
Launch Windows Live Mail, and browse to the "Tools" menu at the top of the screen.
Click "Accounts."
Click the email account that you would like to delete.
Click the "Remove" button.
A message will appear to remind you that any messages belonging to the email account that are not backed up in another location will be deleted permanently.
Click "OK" to confirm.
The account will be deleted immediately.
Click "Close" to return to Windows Live Mail.
Delete Hotmail Adresses
Log in to your hotmail account and click "Help."
Search for "Cancel Account" and select "Why are all my email messages gone?"
Expand the option that says "Close a free Hotmail account" and click "Windows Live Hotmail close account."
Click "Close Account" on the page that opens.
If you do not sign in to your account for 365 days, your account will also be deleted.
Hope this helps.
Computers &... | Answered just now
Generally, Roadrunner Email Error 0x800ccc90 occurs when the hard disk runs out of sufficient storage data. It can appear on your Windows system at any interval due to incompatibility issues and incorrect configuration. This problem may exist for a long time if it does not get solved within the time. Users, who have a technical knowledge, can fix this issue by pursuing certain steps which we are going to discuss in this blog. Besides, we will also talk about the main causes and the symptoms of this technical glitch.
Steps to Fix Roadrunner Email Error 0x800ccc90
Step 1: Download Smart PC Fixer Tool
•Click on the appropriate download link
•Launch Smart PC Fixer Tool for a complete scanning
•Hit Fix tool.
Step 2: Troubleshoot this error manually
•Remove an application, which users have recently installed
•Run Smart PC Fixer Tool
•Choose System Tool
•Then select Uninstaller Tool
•Update Windows 7 to its latest update
Hope this will help you. Thank you
Computers &... | Answered 5 minutes ago
Beyond Micro (BM200MD3U28M) 500 GB USB 2.0 Hard Drive Logo
10 questions posted
Top Beyond Micro Computers & Internet Experts
Dean Rigsby
Dean Rigsby
Level 1 Expert
Joe Bit
Joe Bit
Level 1 Expert
obsteiner
Are you a Beyond Micro Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Beyond Micro Computers & Internet
Most Popular Question
reinstall windows xp home new drive
  • Computers & Internet
