FixYa.com
Mach Speed Motherboard
All Products > Mach Speed > Motherboards
Problems with Mach Speed Motherboard?
Troubleshooting and Support
Solved Problems for Mach Speed Motherboard RSS Feed Post a New Problem
Consustently get "DISK BOOT FAILURE _...
Hey, FixYa :)I have recently upgraded my computer with MachSpeed MSNV-939 motherboard and AMD 3800+ Dual Core CPU and a...
4 Solutions
No boot on start up all fans start but no...
Hello I just put together a new system with all new components from the ground up. mach speed motherboard,AMD 64 X2...
4 Solutions
Mach MSNV-939 motherboard - RAID 0 - How...
Hi, how do you setup up the RAID 0 on this MB? I have two WD Sata hard drives and I went into the SETUP (by hitting the...
1 Solution
Consistent hard Drive BOOT ERROR after an...
have recently upgraded my computer with MachSpeed MSNV-939 motherboard and AMD 3800+ Dual Core CPU and a brand new fan...
1 Solution
Very slow booting
We have a new MachSpeed MSNV-939 motherboard that I just installed in my girlfriends computer about two weeks ago. It...
1 Solution
LAN problems on Mach Speed MSNV-939...
I'm inserting a new machine into my home network - it is hard-wired to a Linksys Router. I have 3 other machines on the...
1 Solution
Fairchild 555 Timer Configuration
I have a device which is controlled by a Fairchild KA555 timer. At present it operates for 5 minutes at each hour, so I...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Mach Speed Motherboard RSS Feed Post a New Problem
Unable to turn on internal USB sonnections...
I don't understand the power source headers for USB ports page15 of manual
Post a Solution
Tips & Tricks
Post a New Tip
Drivers Anyone - Written by DARKLORD1
p5s800-vm - Written by josesilvalve
esd precautions - Written by vgopal1952
Specifications
Key Features
Form FactorATX
CompatibilityPC
ChipsetNVIDIA nForce4
Compatible ProcessorsAMD Athlon 64, AMD Sempron, AMD Athlon 64 FX, AMD Athlon 64 X2
Front Side Bus Speed1000 MHz
Other Features
Package Qty1
Chassis TypeDesktop
Other FeaturesFirewall · Dual Channel Memory Architecture · 64bit Ready
FansFan Speed Control · 3 x 3-pin fan headers
Technical Features
Expansion SlotsPCI Express x16 x 1 · PCI x 4 · PCI Express x1 x 2
Integrated Input/Output PortsSerial Port x 1 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · RJ45 Lan Port x 1 · Floppy Port x 1 · USB 2.0 x 10
Storage Controller Type(s)DMA/ATA-133 (Ultra) x 2, Serial ATA II x 4
RAID SupportSATA RAID 0 · SATA RAID 1
Dimensions
Depth11.56 in.
Width8.19 in.
Warranty
Warranty1 Year
Processor
Max supported CPUs qty1
Socket TypeSocket 939
Memory
Max Supported RAM4 GB
Memory TypeDDR SDRAM
Supported RAM Speeds400 MHz · 266 MHz · 333 MHz
Number of Memory Slots4 x 184 Pin DIMMs
Audio / Video
Audio OutputSound Card · Line Out · 5.1 Channels · SPDIF out
Video InterfacePCI Express x16
Audio InputMicrophone Jack · 1 x Line In
Integrated AudioRealtek ALC655 · AC97 Audio Codec
Communication
Networking TypeEthernet, Fast Ethernet
Mach Speed Contact Information
Main support number580.272.0035
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
