Hi , my seagate external hard disk 500GB FreeAgent Go hard disk getting error, all data is...
(More)
Hi , my seagate external hard disk 500GB FreeAgent Go hard disk getting error, all data is disappear, is any software can recover it pls ? I'm now using file recovery for windows demo version, but seems getting worse, !!!
I keep getting Error notice (and denial) when I try and delete files from my Seagate FreeAgent Go...
(More)
I keep getting Error notice (and denial) when I try and delete files from my Seagate FreeAgent Go 500GB ext. hard drive. I go to delete and I get this prompt: "The folder Seagate Backup" contains names too long for the Recycle Bin". Do you wish to permanently delete it. I select "yes to All" and then get this rejection notice: "Cannot delete "Correspondence (which is a folder). The file name specified is not valid or too long. Specify a different file name" I went ahead and attempted to change the file name and still wont delete. Files and folders are not "read-only" either. Ideally I'd like to erase all of the data on the drive. Is there a quick way to do this? I'm having the same program on my Maxtor drive as well.
I am trying to delete files from my external hard drive. But when I go through the command prompt I...
(More)
I am trying to delete files from my external hard drive. But when I go through the command prompt I get this error: ''The filename, directory name, or volume label syntax is incorrect''. If I press shift+delete I get this error: ''Cannot delete Special Beta Edition: Cannot find specified file. Make sure you specify the correct path and file name.''
replace sears 60179 model:629.46795890 glass stove top severely cracked. we are moving and need to...
(More)
replace sears 60179 model:629.46795890 glass stove top severely cracked. we are moving and need to repace as soon as possible. I still cook on it for at least 8 months.
My problem is I formated the drive, as I wanted to use on Mac. I selected the quick format option,...
(More)
My problem is I formated the drive, as I wanted to use on Mac. I selected the quick format option, after that, I tried it on Mac...it won't pick up as well..says have problem with this drive, cannot be used on the mac...something like that.... Anyone can help?
My HD was originally used on PC (Windows). When I plugged onto MAC, it can read but not write....
(More)
My HD was originally used on PC (Windows). When I plugged onto MAC, it can read but not write. Decided to format to MAC after saving all data. HD was working fine. After using on MAC for a while, decided to plug the HD to PC to transfer some files, this time, the PC can't even see the HD. However, right click on "Removing hardware" shows a HD connected, but still can't find the HD on clicking at "My Computer" icon. Wanted to reformat the HD back to PC format, can anyone please advice. Appreciate your help. Thanks
External hard drives are quite prone to this but it can also affect internal too to a lesser degree The clicking you hear is referred to as the...
written by bob_computer
My hard drive was dead and wasn't recognized by the computer, it didn't even start, just a few clicking noises, which according to some of the...
written by kinggeorg
Please know that if you are depending on an external HD with high rpm (like 5600 or 7200 rpm) to back up your precious files with a USB connection,...
written by exon33
I found this excellent narrative at Tiger Direct of Canada. This is open information I just wanted to give credit for the method used by Tiger Direct...
written by worldvet
Need more storage on your computer? This article will show you some simple steps to help you add a new hard drive and more storage space to your...
by wikihow
This article includes the basics for formatting a hard drive.
Steps
For Windows 9x
1. If you want to save any of the data on the disk, back it up by...
by wikihow
From time to time, we may need to back up a good amount of data. One way to do this is to copy all the data to another hard drive. This guide is aimed...
by wikihow
his guide will tell you how to recover data from a dead laptop, as long as the laptop was running some version of windows or Linux on an x86 platform,...
by wikihow
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
We offer computer consulting services, hardware and... Read More
We offer computer consulting services, hardware and software technical support. We specialize in networking design, installation, and support. No job is too big or too small. For the homeowner we offer a reduced rate. We also build our own pc?s and sell hardware and software
Affordable Laptop and Desktop Repair. We spe... Read More
Affordable Laptop and Desktop Repair. We specialize in Laptop LCD Screen repair, Laptop DC Jack Repairs, Laptop Motherboard repairs, Data Recovery. We offer on-site service, local walk in service where available and mail in services.
