20 Most Recent
Mitutoyo 317-351 Digital Micrometer,uni-mike,1 In,spc Questions & Answers
How do I shut it off
Digital micrometers with LCD displays usually do not have a power on.off feature. Older units have an "on" button only that is used to turn them back on after a predetermined time-out or period if inactivity to conserve battery capacity but newer Mitutoyo mics cannot be turned off. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/dave_fb2c45146b845cea
How do you put a preset in Mitutoyo uni-mics?
Normally you would adjust it to the part being measured then press the 'Zero' button to zero out the display. Now every time you measure the same type of part, it should read zero or the dimension plus or minus from that zero point.
No file error on PC after downloading readings taken from mitutoyo sj-210 surface tester? It used to come up with all readings taken any ideas?
There could be several reasons why the file error is occurring on the PC after downloading readings taken from the Mitutoyo SJ-210 surface tester. One possible reason could be that the file format of the downloaded readings is not compatible with the software installed on the PC. The Mitutoyo SJ-210 surface tester typically saves data in a proprietary format, which may require specific software to open and read the files. If the software is not installed or is outdated, it may result in a file error.
Another possible reason could be that there is a problem with the USB cable or port used to transfer the data from the surface tester to the PC. A faulty cable or port can cause data corruption during transfer, resulting in file errors when attempting to open or read the files.
It is also possible that there is an issue with the surface tester itself, such as a malfunctioning sensor or memory card. In such cases, it may be necessary to troubleshoot or repair the device before attempting to download any further readings.
To resolve this issue, it is recommended to check if the software used to open and read the files is up-to-date and compatible with the file format used by Mitutoyo SJ-210 surface tester. It is also advisable to use a high-quality USB cable and ensure that both ends are securely connected. If these steps do not resolve the issue, it may be necessary to seek technical support from Mitutoyo or a qualified technician.
6/21/2023 8:30:41 PM •
Mitutoyo...
Answered
on Jun 21, 2023
Mitutoyo error code E552?
Error code E552 is usually caused by a communication issue between the CMM and the computer. You can try restarting the CMM and the computer, and ensuring that all cables are properly connected. If the issue persists, you may need to take your CMM to a certified Mitutoyo service center for further diagnosis and repair.
2/15/2023 6:41:53 AM •
Mitutoyo...
Answered
on Feb 15, 2023
Mitutoyo error code E940?
Mitutoyo is a brand that produces precision measuring instruments such as micrometers, calipers, and height gauges. An error code E940 on a Mitutoyo instrument typically indicates a problem with the instrument's communication interface. This can be caused by a variety of issues, such as a problem with the instrument's cable or software, or a problem with the computer or device to which the instrument is connected.
To troubleshoot the issue, you should first check the connections between the instrument and the computer or device to ensure that they are properly connected and secure. If the connections appear to be fine, you may need to update the software on the instrument and computer or device to resolve the issue.
1/12/2023 8:21:54 PM •
Mitutoyo...
Answered
on Jan 12, 2023
QM-Data 200 Mitutoyo with Optoeye-200. How to change or replace battery please?
Apparently the battery is Circuit Board mounted and is a backup memory battery.
Li (lithium) battery • T
he Li battery is mounted on the printed circuit board in the data processing unit "QM-Data". Do not dispose of the data processing unit by burning it. If the data processing unit is thrown into fire, the battery may leak chemicals, burst, or burn violently. Comply with government regulations regarding the disposal method.
and
• This error message indicates that the memory backup battery is low, and that if you continue to use the data processing unit "QM-Data", backup will not be performed. Save the part programs and measured data stored in the internal memory of the data processing unit to the floppy disk or to a personal computer. •
Contact your supplier to replace the battery.
It also says changing the battery removes any saved data.
So if you are looking to do it yourself, look for screws to get inside.
https://www.mitutoyo.com/webfoo/wp-content/uploads/QM-DATA200_2222.pdf
1/29/2022 11:25:16 PM •
Mitutoyo...
Answered
on Jan 29, 2022
How to correct an e671 error message
I realise this question is old, but you never know, might help someone in the future. This particular error is that the probe is not correctly seated, usually the magnets have become slightly loose. The solution is to take the probe head off the cmm, and push the magnets against your surface table or suitable flat surface, this should push the magnets into their correct position. If this doesn't help, it may be that you've managed to break that particular part, if you have a probe rack, try a different probe. Lastly, if you crashed the CMM by hitting something, ensure you didn't bend your probe in the process (and the ruby is still there!), this doesn't help the error code fix, but worth checking as the cmm crashing into something at speed is the most likely cause of this E671 error.
11/24/2021 3:25:06 PM •
Mitutoyo...
Answered
on Nov 24, 2021
