20 Most Recent
ASUS P5B Deluxe Motherboard Questions & Answers
ALL USB PORT IS NOT
If you are running Windows, Do the following:
- Control Panel
- Hardware
- Device Manager
- Check USB settings / properties
Drivers could be corrupted / uninstall and let system find and re-install
Need to find correct device drivers
Try tow links: This is the network driver Asus P5B delux for wifi I have a account but it is free.
From DriverGuide.com.
RTL8187_5123005302006.zip
http://members.driverguide.com/index.php?action=dosearch&qm0=Asus+P5B+delux&dp=3&sm=h&jmd=and&si=74e63a53024e34c37b13a7c2e807a9f0&st=1236564319
http://www.phoronix.com/scan.php?page=article&item=621&num=1
Text for large size
need more information.
here is other options for this error, the first one i think is a page error anf the page error is the page number and the error of the error you are going to look up on that page and you can only get that from the memory manufacture technical support and you may even get i cannot tell you that information because it is classified.
in the olden days it could of been an error in the software program you were using at that time, most of the time it was vedio, audio, text message error, but with the technology anymore it could be anything. again it refering to a page 93
maybe section 5, and the suffex or call letter H
that my best two answers for your question if this didnt help you than post it again for someone else can take a shot at it
thank you for your time in this matter
candymangandy
Motherboard software
Hello, enter here: http://www.hcl.in/
You can find here drivers and manuals about supported P4 motherboards.
Asus P5B bios up-date gone bad
That Flash EEPROM in a socket (so it can be removed) or is it fixed to the board. Either way, look on the Internet for someone who can write Bios for you. They'll tell you what they require, like Board, Bios, Bios Version, then if you have a socket, you can order it and just wait till it received, otherwise you'll be shipping your motherboard out to be reprogrammed.
Look at this too.
You need to be able to reprogram you Bios from another computer. Via some link, like USB, if the Board you have supports that. You'll need a kit. Where do you get one? I do not know.
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
