ASUS MM17DE  LCD Monitor
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with ASUS MM17DE LCD Monitor?
Troubleshooting and Support
Solved Problems for ASUS MM17DE  LCD Monitor RSS Feed Post a New Problem
Acer Aspire 1710 laptop monitor is down
Hi, monitor on my laptop went black in a moment. Looks like computer is continuing to work. When making a closer look at...
1 Solution
L222WT flatron 21.6 monitor is not working
When the monitor is turned on, the LG symbol/logo appears as if it will then go to the Windows Vista page. Instead,...
1 Solution
bzzzing noise coming from monitor
my monitor is making noises, like an electrical bzzz. Could it be a corrupt profile or is it hardware? other than that,...
1 Solution
dell monitor for dimension 2350
lately my monitor keeps blanking out... I was told that a patch could fix the problem.. I hooked another monitor to the...
1 Solution
.ct 2070 display not clear
Hi,  we have the lct 2070 akai monitor.  I have hooked it to the computer and its working but, the fonts are...
1 Solution
1inch black line down right hand of screen
I cannot get a full screen on my acer x223w monitor due to a 1inch black line down right hand of screen. this only...
1 Solution
TFT Screen
I have a TFT monitor with 4 tiny scratches on the surface. Is there a product that will remove these?
1 Solution
Unsolved Support Problems
Unsolved Problems for ASUS MM17DE  LCD Monitor RSS Feed Post a New Problem
Asus 22" strange problem
This is an 2 weeks old screen, couple of days after purchase it started to freeze the picture and then the screen fills...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio5:4
Color Depth24-bit (16.7M colors)
Brightness400 cd/m
Dot Pitch0.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time8 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalBSMI · CE · TUV GS · UL · cUL · C-Tick · VCCI · CB · ISO 13406-2 (Pixel defect guidelines) · Energy star · FCC · TCO-03 · GOST-R · CCC
Max. Viewing Angle - Horizontal150
Max. Viewing Angle - Vertical130
Native (Recommended) Resolution1280 x 1024
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
Loading problems.
Top Monitor Experts
Lollyloo
1 solutions
Computer Hardware, Computer Components...
Ask Me
Wiz
jemmyras
7 solutions
Monitors
Ask Me
Wiz
NathanW
1 solutions
Monitors, PC Desktops, PC Laptops, Wireless Adapters
Ask Me
Guru
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
