I have a Vizio GV47L LCD TV, and my SR605 could not control it. Does anyone has the remote control...
(More)
I have a Vizio GV47L LCD TV, and my SR605 could not control it. Does anyone has the remote control code for this TV? Thanks.The codes from SR605 manual, 0864, 0885, and 1756 did not work.
picture went blank, now TV won't respond to any command and screen is black. I unplugged then...
(More)
picture went blank, now TV won't respond to any command and screen is black. I unplugged then plugged back in to ''reboot'', but to no avail. Control lights on front of TV stay lit, but that's all. It's dead to any and all commands, from any remote, and the on-board control points won't function either. TV is 2-1/2 years old. This is first problem.
slight buzzing from back right of set Picture brightness flickers and is somewhat dimmer apparently...
(More)
slight buzzing from back right of set Picture brightness flickers and is somewhat dimmer apparently in the backlight system somewhere, don't see where others have had this issue... TV still displays pictures on all inputs, no problem with sound
My vizio gv47l went off the other night and now will not power up . i unplugged it and plugged it...
(More)
My vizio gv47l went off the other night and now will not power up . i unplugged it and plugged it back in the lights light up for about 30 seconds then they go off. the remote will not work as well
My Vizio Remote Stopped working on MyGV47L television. I tried reprogramming it with the codes in...
(More)
My Vizio Remote Stopped working on MyGV47L television. I tried reprogramming it with the codes in the manual but they won' work and won't give me full fuction
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
