20 Most Recent Sony Cyber-shot DSC-T50 Digital Camera Questions & Answers
Hi, Indeed, as mentioned below, this is a very well known problem that happens a lot and still today with Sony camera's. Error messages can be found at https://www.sony.com.au/electronics/support/articles/00008857 : E:62:10 is a generic error of the stabilizer. Thousands of users on the Internet have the same problem, take a look at http://sony-e-62-10.tk/ or search E:62:10 on the Internet or on YouTube.
Sony Cyber-shot ... | Answered on Feb 17, 2019
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Sony Cyber-shot ... | Answered on Nov 25, 2018
if you alsow get vibrationOn Sony T100 and similar,
its seems wierd, that too coming from an engineer, but after several posts and several attempts, the best solution that worked for me, was TAPPING the battery cover gently from the side when the camera is on. switch it off. remove battery, and restart again. it should resolve the issue.
Sony Cyber-shot ... | Answered on Nov 11, 2018
It's a technical glitch. Loose connections. Take it to a sony repair shop.
You could try the method below:
This might sound weird:
Hit the bottom of the camera on smooth, hard surface.
(Do his at your own risk)!
Defective focus unit in the lens.
Sony Cyber-shot ... | Answered on Nov 04, 2018
hi setos,
here are more information about the error. sony may have not come up with a solution for this one yet but here are articles you may want to check on.
http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Sony/E.62.10_on_DSC-T9
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-t10_question.html?qid=15192
regards,
voodoo
Handshake correction error. Needs to be repaired.
are there any additional problems (vibration or noise ?)
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sony Cyber-shot ... | Answered on Apr 05, 2013
Touch MENU. Select Toolbox-1 then "A".
Sony Cyber-shot ... | Answered on Mar 09, 2013
All your pictures are saved on the memory card of your digital camera automatically.So you can recover pictures from memory card with data recovery software.I have a professional program on my computer that can recover data after deeply scanning your memory card to look for lost data you accidentally deleted or formatted. But you had better have stopped using the memory card of your camera. Because, once the pictures were overwritten by new ones,they are gone for good.By the way,you can download it and scan your memory card for free to preview whether your erased pictures can be recovered.Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Sony Cyber-shot ... | Answered on Feb 09, 2013
go to google you can get language translator to change japanese to english
Sony Cyber-shot ... | Answered on Jan 12, 2013
Power up camera, press Home, Memory management, format, OK
That will delete all pictures on memory stick at once.
Sony Cyber-shot ... | Answered on Dec 18, 2012
Go to the setup menu there is function auto preview on and off.select on off mode .
Sony Cyber-shot ... | Answered on Jun 16, 2012
Sony Cyber-shot  DSC-T50 Digital Camera Logo
63 questions posted
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
sony cybershot
  • Cameras
