FixYa.com
Tyco Electronics 1739L  LCD Monitor
All Products > Tyco Electronics > Monitors
Problems with Tyco Electronics 1739L LCD Monitor?
Search inside Tyco Electronics 1739L LCD Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for Tyco Electronics 1739L  LCD Monitor RSS Feed Post a New Problem
Monitor going to sleep
I think we lost our connection.
1 Solution
What is the proper way to clean an LCD...
What's the best way to clean like dust off an LCD Screen without causing damage?
1 Solution
Swapped colors in the monitor...
My samsung 55v monitor had a problem with its cables.. so i cut the cable n replaced the connector... bt i hav swapped...
1 Solution
pink monitor
I've swopped out my pinkl monitor screen and screen is still pink on the replacement. What can I do to fix?
1 Solution
Horizontal band of Brightness
After leaving my monitor on for only a few minutes now, the entire screen will shrink down to about one pixel high and...
1 Solution
Monitor is putting out a really annoying...
A couple of weeks ago, my monitor started randomly (?) putting out a very high 'beep'. Its not like a 'notification...
1 Solution
oblong pictures
I have just bought this monitor. Photo images are stretched across the horizontal axis making every one look like they...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4
Color Depth24-bit (16.7M colors)
Brightness280 cd/m
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time25 ms
Viewable Picture Size17 in.
Technical Features
Form FactorWall Mount
Regulatory ApprovalCE · UL · cUL · C-Tick · VCCI · CB · SEMKO · FCC · IC
Input DeviceTouch Screen
Synchronization Range - Horizontal31.5 - 80 kHz
Max. Viewing Angle - Horizontal178
Max. Viewing Angle - Vertical178
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 720 x 350 · 720 x 400
Synchronization Range - Vertical56.3 - 75 Hz
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
