20 Most Recent Palm Treo 750v Smartphone Questions & Answers
you need a rom match your language
Palm Treo 750v... | Answered on Oct 18, 2013
try to reset the phone
Already replied to your email
Palm Treo 750v... | Answered on Jul 28, 2013
Call your service provider's customer care and ask to send GPRS settings and activate GPRS for your card.You would get settings as sms. Just save it and access GPRS.
Palm Treo 750v... | Answered on May 18, 2011
i unlocked my Palm HTC using codes from http://www.mobileunlocksolutions.com/ , try if your phone is listed for unlocking
Palm Treo 750v... | Answered on Feb 25, 2011
Hello
It is impossible to change your IME number because it was provided by the manufacturer.
Each phone has its IME number for security purpose and can never be change.
Regards.
Palm Treo 750v... | Answered on Sep 02, 2010
I believe this means your battery is no longer sustaining a charge enough to power your phone. I would recommend replacing the battery. You should be able to buy a new or used battery from your phone vendor or authorized reseller.
Good Luck,
Jesse
Palm Treo 750v... | Answered on Jan 13, 2010
i had this problem with my tmobile shadow. i had to get a bluetooth earpiece and everything worked fine. if not you may need to get a new phone.
Palm Treo 750v... | Answered on Jan 07, 2010
Normal 0 The best thing I can do for you is to refer you to the free palm chat. For the palm phones I have to know what service provider you use to be able to get you to the correct link. So here is a link to palm support for your phone. Click on the icon for your service provider (Rodgers, AT & T or Palm) From there you want to click on the words “downloads” at the top of the page. From there you will be able to download all the software you need to get your phone up and running. Best wishes…I hope this will help you.
http://kb.palm.com/wps/portal/kb/na/deviceselector/page_en.html#NA%20Phones:Treo%20750
Palm Treo 750v... | Answered on Nov 27, 2009
Mouais, il manque un peu d'info pour vraiment cibler le probleme mais je vais commencer par y aller avec le plus simple et évident, et si ce n'est pas le problème, récris un commentaire pour préciser pas de son dans quel sens. Donc, tout simplement a priori comme ca, je dirais que le haut-parleur de ton tréo est brisé, ou encore qu'un des connections ou soudures qui le relient a la carte principale du tréo a cédé. Si tu es sur que ce n'est pas ton cas, alors faudrait que tu précises si t'as juste aucune sonnerie mas que tu entends quand meme quelques sons quand par exemple tu fais jouer un MP3 ou quelquechose. Ou encore si vraiment tu n'entends pas parler la personne quand elle décroche mais que tu entends ta sonnerie quand quelqu'un t'appelle. Bref, essaye d'etre le plus précis possible et de me dire tous les modes ou le son fonctionne ou fonctionne pas. Voila, donc en espérant t'avoir un peu aider, sinon j'attends de tes nouvelles pour pouvoir essayer de mieux comprendre le probleme et te trouver une solution.
Palm Treo 750v... | Answered on Jul 28, 2009
unfortunately you cannot just switch languages on the treo or really any Windows Mobile Treo or Palm
They release the phones with one language installed in whatever country and thats about it.
You can buy a Treo 750 in english, but not change the language
Palm Treo 750v... | Answered on May 28, 2009
Contact your network provider to get them to send you the settings. They can possibly be found on the website if not you will have to phone customer services.
Palm Treo 750v... | Answered on May 26, 2009
need a puk code for my palm treo 750
Palm Treo 750v... | Answered on May 02, 2009
We send the second List (Cash-Report from 30.04.2008). Beim festen Vorschuss haben wir per 30.04.2008 CHF 200'000.00 zurück bezahlt.
Mit freundlichem Gruss
Palm Treo 750v... | Answered on Apr 12, 2009
if you got external memory card then put the songs in memory card through pc (if you laptop does not have the sd card slot then you need to do it with card reader)
or simply connect treo with pc through usb and upload it
Palm Treo 750v... | Answered on Mar 24, 2009
set different ring to different callers.
Palm Treo 750v... | Answered on Jan 30, 2009
Go to the carrier's website they usually have a download section where you can get the software.
Palm Treo 750v... | Answered on Jan 12, 2009
Have you tried removing the battery then putting it back in?
Palm Treo 750v... | Answered on Dec 31, 2008
You have an earpiece failure. You would need to get the earpiece swapped out by a phone technician or you would need to call your carrier and speak with someone about getting another device through warranty.
Palm Treo 750v... | Answered on Dec 22, 2008
Palm Treo 750v Smartphone Logo
Popular Tags
35 questions posted
Popular Products
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Treo Palm
  • Treo Palm
Most Popular Question
change palm treo language from spanish
  • Computers & Internet
