20 Most Recent
Epson Stylus Photo R260 InkJet Printer Questions & Answers
Flashing red lights
this means your printer wast pad is full but your printer can be reset let me no and i will send you the info on now to reset your printer
My epson R260 says Service
Many of the Epson printers ink cartridges have a sensor that allow the printer and the associated software know when to replace the printer ink cartridges (even when the cartridges have ink within them) and/or when the printer needs to be cleaned. In some cases you can bypass this message by following either of the below steps.
Use printer buttons to reset
Use the printer buttons to reset the printer by pressing and holding the "Stop", "Maintenance", and "Power" buttons all at the same time.
Ink light on changed ink still wont print
it sounds like the printer has not accepted the changed cartridge.
Try turning the printer off at the mains for 30 seconds then back on again, it sometimes works, or if that fails take out the cartridge's turn off printer for 30 mins then back on re insert inks and see if that works.
If it fails then there could well be a chip set failure on the cartridge you have replaced or maybe another cartridge within the set.
It's well worth saving the cartridge too as compatibles sometimes fail to be read by your printer but rarely the actual cartridges fail, you can put that same cartridge back in later for it to be accepted by the printer.
