i have 1 printer hooked up, i remember it took me a long time to do the irst one. i want to hook up...
(More)
i have 1 printer hooked up, i remember it took me a long time to do the irst one. i want to hook up a 2nd printer
Just bought this printer and trying to connect it wiresly. On set up it asked to connect to router...
(More)
Just bought this printer and trying to connect it wiresly. On set up it asked to connect to router via cable. I did it, but my MAC shows message that printer can't be found. So I can't finish configuration. Tried via usb, works. Tried ethernet cable straight in printer and then add, nothing.
Helllllp.
When I try to print to printer (which is also a copier) I cannot print and it is set up to print...
(More)
When I try to print to printer (which is also a copier) I cannot print and it is set up to print wirelessly with a netgear router. When the info gets to the printer it says disk full. Some days it will print and some days it won't. Just started doing this about a week ago. Had the copier checked out by the copy guy and he cannot figure out what is wrong with it he thinks it is a computer or router problem.
I have a dlink 714 wireless router and the wgps606 is wirelessly connected to it. My printer is...
(More)
I have a dlink 714 wireless router and the wgps606 is wirelessly connected to it. My printer is samsung 2850. This setup is accessed by 3 laptops on which i have installed the neatgear software. The problem is that when i start the setup everything works fine initially and i can print from all three laptops wirelessly. however if printer is idle for 20-25 mins, the next time i give print command from any of the laptops nothing prints. Moreever i cannot even ping the ip address of the wgps606 although i can ping the ip of the dlink router. However if i switch of and switch on the wgps606 everything again works fine till such time the printer again remains idle.
I have cable modem plus dlink cable router. I go into wizard of print server, enter encryption key...
(More)
I have cable modem plus dlink cable router. I go into wizard of print server, enter encryption key that is on router, but it won't save settings (or connect). Is it possible to have this print server (a switch?) relaying the signal from the router? Help much appreciated. Mike
Help, my wireless printer stopped just stopped printing after I moved it to a new location,...
(More)
Help, my wireless printer stopped just stopped printing after I moved it to a new location, everything seems hooked up fine and I can even print a test page right from the computer but nothing else prints. What am I missing?
I have followed all directions in the setup wizard three times. The setup program works as described...
(More)
I have followed all directions in the setup wizard three times. The setup program works as described in the manual. When I get to the "print test page" button a test page is sent to the printer (I see it in the print queue) but nothing happens. The printer works fine when connected directly to my laptop. My operating system is windows XP with service pack 2. The set up program adds a Standard TCP/IP port assigned to the G55. The IP address is the same as the print server with P1 added to the fourth number. Sure seems like it ought to work......... Need help
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
We offer computer consulting services, hardware and... Read More
We offer computer consulting services, hardware and software technical support. We specialize in networking design, installation, and support. No job is too big or too small. For the homeowner we offer a reduced rate. We also build our own pc?s and sell hardware and software
Affordable Laptop and Desktop Repair. We spe... Read More
Affordable Laptop and Desktop Repair. We specialize in Laptop LCD Screen repair, Laptop DC Jack Repairs, Laptop Motherboard repairs, Data Recovery. We offer on-site service, local walk in service where available and mail in services.
