20 Most Recent Optimus DC-5347 Digital Camera Questions & Answers
4answers
Retrieve deleted files optimus mpeg4 camera
There are some software now that you can use in retrieving deleted files from your camera and you can also find some photo shop that offer data retrieval,
9/5/2013 2:33:19 AM • Optimus DC-5347... • Answered on Sep 05, 2013
manual
2answers
I bought my optimus camera
If you're using a memory card in the camera, just get yourself a card reader and use it for downloading. Then, you don't need a software CD. typrice_258.jpg
7/8/2013 10:51:24 PM • Optimus DC-5347... • Answered on Jul 08, 2013
I need a charger to my digital camera
They should be available on the used market. Search by your model number.
11/18/2012 2:12:58 AM • Optimus DC-5347... • Answered on Nov 18, 2012
What does,card full,means?
that means that you have used up the available space on your Memory Card.Solution: move some files to your computer
9/19/2011 9:15:24 AM • Optimus DC-5347... • Answered on Sep 19, 2011
TRANSFER PICTURES
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/10/2011 3:09:37 AM • Optimus DC-5347... • Answered on Apr 10, 2011
Optimus8mp camera zoom will not retract when you
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
10/28/2010 8:23:50 PM • Optimus DC-5347... • Answered on Oct 28, 2010
Erreur objectif
that's mean that the problem is inside not in programmation
and you will have to open the camera to solve the problem
7/21/2010 3:23:35 PM • Optimus DC-5347... • Answered on Jul 21, 2010
2answers
Camera lens is broken and camera won't turn on.
I had the exact same problem on a Nikon. Unfortunately, after having dealt directly with Nikon in Richmond BC, the cost of fixing it was greater than the cost of a new camera, even Nikon told me they'd recommend I just buy a new camera (and no, not selling me on other Nikon equipment, just a new camera in general). So I'd say you'll most likely have to buy a new camera. I know that's not what you wanted to hear, but its life unfortunately.  Good luck.
7/5/2010 11:00:10 PM • Optimus DC-5347... • Answered on Jul 05, 2010
Unwanted pictures
Bring up the picture you wish to delete and press the button with the garbage can icon. Follow the on-screen instructions.
6/21/2010 11:44:04 PM • Optimus DC-5347... • Answered on Jun 21, 2010
Okay I need to be able to download my pics to my
Get a card reader.
6/19/2010 6:45:47 AM • Optimus DC-5347... • Answered on Jun 19, 2010
Camera value
Roughly about 35 dollars if the camera is in good condition and everything works
5/27/2010 7:35:51 PM • Optimus DC-5347... • Answered on May 27, 2010
Camea not recognized by Skype,
This can really be a driver issue, but what you can do here first is to uninstall and reinstall the camera from your computer and then check if that fix the problem and if still same problem, you can do a online update via Device manager.
5/15/2010 6:52:00 PM • Optimus DC-5347... • Answered on May 15, 2010
Memory card for an Optimus 5.0 digital
The memory card compatible for a Optimus 5.0 digital camera is the SD form.hope this helps
4/6/2010 4:52:44 PM • Optimus DC-5347... • Answered on Apr 06, 2010
My camera lens open half way and stops and the
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
2/2/2010 2:25:12 PM • Optimus DC-5347... • Answered on Feb 02, 2010
Canyou get pictures put back on the memory card
Yes, you can use a card reader or use window> Mycomputer> camera as a card reader to put the pictures backo n the memory card. It can be as simple as find the pictures and drag them on to the cad. the problem is that most cameras will NOT display them once they are put back on the card. So it may be a futile exercise if you are trying to put the picture back on the card to then display them on the camera or on TV using the Av cable.
1/30/2010 7:13:46 PM • Optimus DC-5347... • Answered on Jan 30, 2010
Optimus DC-5347 Digital Camera Logo
47 questions posted
Top Optimus Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you an Optimus Camera Expert? Answer questions, earn points and help others
View Most Popular
Optimus Cameras
  • Optimus Cameras
Most Popular Question
owners manual optimus 16 3879
  • Cameras
