Neovo A-17  Monitor
Problems with Neovo A-17 Monitor?
Troubleshooting and Support
Solved Problems for Neovo A-17  Monitor RSS Feed Post a New Problem
sink problem
when moniter start then with in two hour in one or two times sink one or two seconds only above side
1 Solution
internet problem
my internet not working properly .it stops after working for few secconds
1 Solution
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Sylvania (ProView) CL2072b Circuit board...
I have discovered that the fuse on the circuit board as blown. I've jumperd it with a very tiny piece of wire wrap wire...
1 Solution
3yr old got ahold of monitor
We have an older computer that I had decided to give to my 5 yr old daughter so that she could play with educational...
1 Solution
Problem with monitor
My monitor looks like it has a drop shadow...all the type has a lightened verson of the text or graphics just to the...
1 Solution
I have to heat up my CRT
My problem -  Relisys TE770-RU 17'' CRT Monitor When my monitor was working correctly, I would plug in the...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio5:4
Contrast Ratio500:1
Dot Pitch0.264 mm
Response Time4 ms
Viewable Picture Size17 in.
Technical Features
Native (Recommended) Resolution1280 x 1024
Neovo Contact Information
Main support number1-408-321-8210
Email supportservice@neovo-usa.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
fwadley Wiz
2 solutions
Ask Me
silentspo Guru
1 solutions
Ask Me
leethedeu Guru
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
