20 Most Recent Sceptre X32GV-Komodo 32 in. LCD Television Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sceptre... | Answered on Dec 10, 2014
Do a reset to this set and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sceptre... | Answered on Oct 25, 2014
www.shopjimmy.com has everything you need. No.. I do not work for them, but I do get my TV parts from them
Sceptre... | Answered on Jan 09, 2014
my sceptre tv is every time turn off how can i fix?
Sceptre... | Answered on Oct 14, 2013
I replaced my own part and it works as new again .Go to ( Power-On.com )Look up part #LCD225-6M Power supply it only cost $65.00 and ups shipping was $10.46 2 day later I got it and 15 mim. later we were watching TV again
I have a 32inch Sceptre TV. Recently the picture stopped showing and smoke ces from the back of the set. I unplugged it and am waiting on the authorzation to return it as it was just purchased in February. Like the other writer I have another these sets in my bedroom. If anyone has further information I would appreciated it.
Sceptre... | Answered on May 04, 2013
If you mean the blue color spectrum isn't there and you are using component cables, check both ends of the blue connections to make sure they are pushed all the way in.
Sceptre... | Answered on Apr 17, 2013
Hi! - if your using component cabels (red blue and green) make sure all of them are plugged into the right sockets on the tv
Sceptre... | Answered on Oct 20, 2012
The usual suspects include main and other boards it is connected to up to and including a defect inside the display panel itself which is of course fatal.
Sceptre... | Answered on Jun 15, 2012
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sceptre... | Answered on Jan 22, 2012
The lcd tape under the metal frame the screen side may be bad put something between there to increase pressure on the tape connection to the lcd.
Sceptre... | Answered on Jan 21, 2012
Unfortunately there is no service manual availabe with me for this model but I think the fault seems related to a reset or even a poor solder joint in the processor section. so to start off it will be best to try and see if the set works fine with a good cooling within, if so heat up the processor area as a simulation to make the fault come up. If so try and solder the IC pins and connector ends, use a good observation lamp to check along with a good soldering iron or station.
Attempt only if you have worked with such boards or it can be tampered with a wrong move.
Sceptre... | Answered on Oct 15, 2011
This type of issue is usually caused by blown capacitors on the power supply board. If you wan to do the repair yourself then go to our web site at: www.ccl-la.com/capacitors.htm and look at the pictures of what to look for in your monitor. Now open the unit and look for the power supply board, replace all parts hat look like the pictures and have even slightly bulging tops. The page on our wen site gives more information about the replacement parts. If you need to order parts we do stock them for same day shipping. If you don't want to do the repair yourself we do offer a repair service for your model for $45 plus return shipping. Let us know if you have any additional questions by email at tech@ccl-la.com.
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sceptre... | Answered on Aug 15, 2011
Hi.
This is an all too common problem these days.
Your tv has suffered from capacitor failure.
This is affecting thousands upon thousands of people, as the companies that made all of these junk capacitors decided to leave them in circulation rather than pull them and make good ones.
See, what happened is, back in 1995 or so, a group of about 15 electronics parts manufacturers were making cheap capacitors.
Well, they collaborated on research and development, and that was a big problem.
They had come up with a new formula for the gel inside the capacitors.
Unfortunately, their math was wrong, and about 5,000,000 parts were made and put into distribution before they figured out that they were all junk.
Now, rather than pull the bad parts off the market, they chose instead to do nothing, in the hopes that the parts would somehow magically work as if they were good ones.
Well, they failed miserably, some of the parts are going out within just weeks, hile others are only lasting within 2 to 3 years.
That is about 1/10th of how long the are supposed to last.
About 25 to 30 years is the life cycle for a good quality capacitor, not months.
Now, I know this sounds real bad, but at least there are places out there that have specialists trained to do the repairs.
Fry's, BestBuy, Radio Shack,Staple's, and CompUSA all have people that have been trained to do this exact repair.
Now, before you pay to have it fixed, you will want to have estimates made, because you may find that it is actually cheaper to buy a new set rather than pay to get the old one fixed.
I know this sounds bad, but at least it can be repaired if you choose top do so.
I hope this helps you to not only know what is wrong, but now you know why it failed, and what you can do to resolve this.
Good luck to you, and have a good day.
Sceptre... | Answered on Jun 14, 2011
Sceptre X32GV-Komodo 32 in. LCD Television Logo
Popular Tags
43 questions posted
Top Sceptre Televison & Video Experts
leeboy3909
Level 1 Expert
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sceptre Televison & Video
Most Popular Question
need replace inverter
  • Televison & Video
