When I turn on my Westinghouse SK-26H590D with the remote it powers on I get a black screen with...
(More)
When I turn on my Westinghouse SK-26H590D with the remote it powers on I get a black screen with "VGA No signal" then after a few seconds it turns off and there is orange coloerd light instead of blue
DVD will not play, cannot eject DVD. The symbol for the DVD and ''close'' are displayed on the...
(More)
DVD will not play, cannot eject DVD. The symbol for the DVD and ''close'' are displayed on the screen.
I have a westinghouse tv sk-26h590d. Two dvd's were put in the dvd player. I was able to get one out...
(More)
I have a westinghouse tv sk-26h590d. Two dvd's were put in the dvd player. I was able to get one out and one is still stuck. the dvd player does not acknowledge that there is a dvd in the player. How do I fix?
Need replacement remote for this TV. Universal remotes do not work. How do I obtain a replacement or...
(More)
Need replacement remote for this TV. Universal remotes do not work. How do I obtain a replacement or find another remote which will work. The cable remote won't work with this TV. Thanks.
Scan shows 3 analogue no digital . prior to the transition about 13 HDTV were available off the air...
(More)
Scan shows 3 analogue no digital . prior to the transition about 13 HDTV were available off the air with antenna in the attic.
My Westinghouse Model SK-26H590D TV worked fine before the big DTV switch that happened recently....
(More)
My Westinghouse Model SK-26H590D TV worked fine before the big DTV switch that happened recently. This TV along with 3 other HD TV's share access to an indoor HDTV antenna. ALl of my other TV's work fine. I have tried scanning several times, un-plugging the TV then scanning and even did a system reset then scan and nothing has helped. It does find the analog stations but no digital.
DVD player made a whining sound from time to time, not always though. Thought it might be rewritable...
(More)
DVD player made a whining sound from time to time, not always though. Thought it might be rewritable discs, but was the same with movies. Now it will not play at all, just makes a kind of a clicking sound at consistent intervals, every 3-5 seconds. Is this an expensive problem to fix?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
