20 Most Recent LG 42PC5D Television Questions & Answers
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
LG 42PC5D... | Answered on Feb 14, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
LG 42PC5D... | Answered on Feb 07, 2017
the tv codes for lg is 0056
LG 42PC5D... | Answered on Apr 12, 2015
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
LG 42PC5D... | Answered on Dec 03, 2013
2897,2819,2854. These are the codes to check with LG brand TVs. Try these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
LG 42PC5D... | Answered on Oct 30, 2013
The internal power supply may have failed.
LG 42PC5D... | Answered on Oct 28, 2013
These blinking are fault indications. From the number of blink occurs at one time switch ON, you can get an idea about the faulty circuit section inside it. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
LG 42PC5D... | Answered on Apr 02, 2013
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
LG 42PC5D... | Answered on Aug 07, 2012
Look first to see if same issue when using a DVD etc connected to a rear audio/video input--this might narrow down where the problem is.
LG 42PC5D... | Answered on Jun 17, 2012
Clicking noise maybe power on latch relay contacts eroded. Need replacement.
LG 42PC5D... | Answered on Feb 09, 2012
maybe your tv has a defect,go to the LG service center ask a technician to fix your tv
LG 42PC5D... | Answered on Oct 24, 2011
Televison & Video Logo
83 questions posted
Ekse
View Most Popular
  • LG Televison & Video
Most Popular Question
lg 42pc5d tv remote sensor quit working
  • Televison & Video
