20 Most Recent
Samsung ML-3051ND Laser Printer Questions & Answers
Fuser door open?
Try fuser door should be in the back. If it is close, it could be a door sensor issue. Also make sure that the fuser is in correctly.
6/10/2019 2:02:06 PM •
Samsung...
Answered
on Jun 10, 2019
3051 page prints crooked
most it may be the problem with the catridge , after refilling it it show same problem you can reset it by doing the catridge
6/7/2013 7:13:48 AM •
Samsung...
Answered
on Jun 07, 2013
Page prints crooked
Try doing an alignment in the program settings. if it does not wok then you have to change the printer
6/7/2013 7:12:09 AM •
Samsung...
Answered
on Jun 07, 2013
Lsu hsync error cycle power
give back cover of the printer, which is located Fuser Fuser is carefully removed after it opened by pressing the two side screws to remove out.Se Fuser notice printed contacts are clean and in particular an electric tab located somewhere in that cloud right des.Reinstall Fuser ... success!
4/12/2011 7:15:13 AM •
Samsung...
Answered
on Apr 12, 2011
My printer is showing the
hello,
your Ml 3051ND printer have bad laser scanner unit(LSU UNIT)you have to replace this unit.best thing is call for service.
or some time laser scanner unit wire harness was damaged. so best solution is call for service.
2/8/2011 8:49:06 AM •
Samsung...
Answered
on Feb 08, 2011
