20 Most Recent Philips 42PF5321 42 in. EDTV-Ready Plasma Television Questions & Answers
This might help you. Try starting on page 27 of this:
http://www.scribd.com/doc/6528782/Philips-42pf7320
Philips 42PF5321... | Answered on Jun 11, 2014
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF5321D/37&slg=en&scy=US&mid=Link_Software
Under firmware upgrade software.
Just follow the instructions and you'll be good to go :D
please rate if this helps!
Philips 42PF5321... | Answered on Mar 08, 2011
are you any good at soldering?
blown capacitors on the power supply board, LJ44-00101C
C8059 and C8060
hope this helps
John
Philips 42PF5321... | Answered on Feb 17, 2011
Hola! El calentamiento podr?a valer la pena el electrolytics ups con un secador de pelo antes de encenderlo. Tenido un problema similar en un plasma Philips causada por una duff condensador.
Jose'
Philips 42PF5321... | Answered on Oct 14, 2010
is it a pico fuse or ceramic glass type fuse?
Philips 42PF5321... | Answered on Jul 13, 2010
Sounds like one of the buffer boards have gone out on you, it would be hard to tell witch one this would require someone to come and look at the tv and run some test. But I know for sure its one of the buffer boards that is causing this issue.
Thanks for using fixya.com please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Philips 42PF5321... | Answered on Jun 24, 2010
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem.
But, I can't say it's 100% that is the source of the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Philips 42PF5321... | Answered on Jul 28, 2009
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. This will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, red light blinging codes, test points, and part# lists. Usually, cost under $20.
Philips 42PF5321... | Answered on Jul 05, 2009
Usually it's the Y-sustain board and also a possibility the it wiped the upper and lower Y drive boards also. I advise you to have it looked at by your local service center.
Philips 42PF5321... | Answered on Apr 08, 2009
Philips 42PF5321 42 in. EDTV-Ready Plasma Television Logo
27 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
red light blinking 4time no
  • Televison & Video
