FixYa.com
Eizo CG-19  LCD Monitor
All Products > Eizo > Monitors
Problems with Eizo CG-19 LCD Monitor?
Search inside Eizo CG-19 LCD Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for Eizo CG-19  LCD Monitor RSS Feed Post a New Problem
How to clean Screens of High End Monitors?
1 Solution
My laptop screen is experiencing burn-in...
My laptop screen is experiencing burn-in along the taskbar. Is this normal?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
The monitor turns off and on repeatedly.
It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again...
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
faulty screen
the screen has like waves going across,it comes and goes,ive tried different cables,and i moved it to another room,and...
1 Solution
Blank screen
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4
Color Depth24-bit (16.7M colors)
Contrast Ratio450:1
Brightness280 cd/m
Dot Pitch0.294 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time20 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalCE · TUV GS · UL · FCC Class B · C-Tick · CSA · CB · TUV-S · ISO 13406-2 (Pixel defect guidelines) · Energy star · TCO-99 · TCO-03 · TUV-ERGO · CCC
Digital Video Input StandardDVI-I
Synchronization Range - Horizontal30 - 82 kHz
Max. Viewing Angle - Horizontal170
Max. Viewing Angle - Vertical170
Native (Recommended) Resolution1280 x 1024
Synchronization Range - Vertical49 - 86 Hz
Eizo Contact Information
Main support number1-888-900-8383
Email supportsupport@eizo.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
