20 Most Recent RCA TH1011 MP3 Player Questions & Answers
I suspect the new format is not compatible with at of the player. The manual says the the player should only be formatted to "FAT" . If it has been formatted to FAT32 or any other FAT. Then it will only work as a hard disc. You should change it back. However the manual does say that changing it over (frequently) can cause permanent damage to the unit.
As this seems to have been designed to work with Windows 98, or XP you might be able to ask the Windows 7 Computer to treat it as that.
RCA TH1011 MP3... | Answered on Jun 21, 2017
I solved the problem myself.
I removed battery, inserted a new one and it worked properly.
Thanks for your help.
RCA TH1011 MP3... | Answered on Oct 02, 2009
After it is turned on, you need to push the power button again to begin playing....To shut down, hold the power button....
It's not the best player!
RCA TH1011 MP3... | Answered on Oct 24, 2008
You can get the latest downloads, register your new RCA product, check
out the FAQs or find an answer in the User Manuals. Product How-To
Videos, Forums and Step-by-Step Solutions will be coming soon.
TRY IT ...........
RCA TH1011 MP3... | Answered on Dec 20, 2007
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod
Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc.
1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window.
2. Import files to the software from computer in the following four-way:
I. Drag and drop the music files into iTransfer directly.
II. Click the button "Add" on the upper part which is beside the left sidebar.
III. Click the button File > Add > Add File/Add Folder on the top right corner of the window.
IV. Right click on the library and select Add File or Add Folder.
3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed.
music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_0.jpg For more details, check: How to Download Music from YouTube to iPod
RCA Audio... | Answered 3 days ago
This could be anything but I would guess you probably have a short in the system.If you could give me more information I may be able to help you better.
hardrocko
RCA Audio... | Answered on Sep 11, 2019
PCM mode is a digital audio file that should be sent to the soundbar via an optical or coaxial digital audio cable. The coaxial digital audio cable uses an RCA plug but not the L/R stereo channels of analog audio. The aux input is usually the 3.5 MM cable from a computer, CD or MP3 player or a cell phone or tablet.
First, which type of RCA cable is connected between the sound bar and the TV? Second, are you sure that the TV connection is an audio out? (A number of recent TVs have only one audio output. This means there is only the optical audio out and not even a headphone jack.)
Once you double-check the input at the sound bar, choose the Line In input if you are using the stereo RCA cable. If you are using the Optical input, select that input. Use either the Mode button or the specific input button on the remote. Then double-check that the TV is set for the appropriate audio out.
I hope this helps. Please add a comment with the model of the TV and the sound bar for further information. I looked at the ONB18SB001 documentation for some of this. The manual for this Onn soundbar is available at Manuals Lib. See https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=12#manual for the list of input modes and the input to which they correspond. Here is the image of the inputs on the back of the ONB18SB001: https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=7#manual .
RCA Audio... | Answered on Sep 06, 2019
Hello Kathie, indicate model of the equipment that you are commenting, to be able to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Kathie, indica modelo de los equipos que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
RCA Audio... | Answered on Sep 05, 2019
Google (rca)(RP3528-c)(manual) without parens OR contact RCA directly to request.
RCA Audio... | Answered on Aug 15, 2019
If this happens with more than one disk then the laser mechanism of unit is fubar - unit needs replacement.
RCA Audio... | Answered on Jul 18, 2019
RCA TH1011 MP3 Player Logo
15 questions posted
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
play mp3 files from device
  • Audio Players & Recorders
