20 Most Recent
Xerox Phaser 6360 Laser Printer Questions & Answers
What is causing misfeeding?
Either the paper is slipping and not reaching the sensors at the right time. or a sensor flag is broken/missing/out/stuck and the device stops the paper thinking there's a jam. Clean all the paper feed rollers with a clean lint-free towel and water only. See if that will improve the grip of the rollers. If they appear shiny, replace the rollers. They are too worn out to continue working properly.
Why xerox phaser 6360dn is printing only pink
Anonymous, Have you tried to print the test print, is that Pink?
Have you tried too print the configuration sheet, is that Pink?
Have you tried to run purge sheets are they Pink?
If the answer is yes to all the above then has the printer been moves whilst still hot or warm, you could have mixed the colours.
If all the colours were mixed together then you would have a dark dirty Brown. Further investigation needed.
Good Luck.
I have a Xerox Phaser 6360 that one day just
Your machine uses solid ink wax blocks. So no calibration is necessary. Does the self test print look good. I suspected not.
Check out the Xerox.com website. It could be a problem as you machine is no longer sold.
Sorry.
Not printing cyan on xerox 6360
INK PROBLEM Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer than replace the print head.
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Magenta cart. wont print
The problem is most likely a bad Image Unit.
Xerox guarantees their supplies to be free from defects as long as their is a life percentage left and will replace it for free.
Take it back to the store you purchased it from and ask for a replacement, or have them request a replacement for you.
If the magenta fails (within 100 pages) after you replace the Image Unit, then your toner dispense mechanism is failing for the magenta toner, and either a dispense motor will need replaced, or the toner auger will need to be unclogged or replaced.
