20 Most Recent
Astar LTV-20PW 20 in. EDTV-Ready LCD Television Questions & Answers
Power supply
I do not have power supplies for sale, I repair them. It seems that is not easy to find service parts as the manufacturers of these LCD do not manufacture new assemblies for servicing.
If you need further assistance, write an email to
[email protected]
Will not turn off.
It would be wise to have a local electronic tech check the power assembly to see if something is blown. Do you smell anything burnt in the TV?
Code for astar tv
ASTAR LCD TV remote code for directv: 11531, 11548, 11738
The 11738 worked for me!
Astar LTV-32HGB blinking power indicator light
this sounds like typical power supply problems. these units have a stand-by power thats always active;even when unit is off. this allows the settings to be remembered by the u-con. (microprocessor) when you unplug the unit it will reset to factory default, thus erasing faulty power-supply data from improper voltages.(usually low readings) swollen capacitors on power-pcb will effect operation. recommend replacement of all electrolytic caps on power board. even smd's (surface-mounted-devices) can be leaky. they can be checked in circuit with an ESR meter. this is an analog sweep meter (needle gauge, not digital) that can detect faulty, leaky capacitors.
Astar 20
Your tv having the main board defective. please call 323-767-6030.
and I will go through with you.
Astar LTV-20PW
your lcd plug fried company sent me replacement first time now I have to find a place to sell me one also make sure tv is on a good power surge protector, can't say it won't happen again. cause i've been tere done that.
Tv output
there is a button on and off press it a few times it goes to tv,video, video2 , ect. may try that mine came on video2 which is the tv picture.
No Picture or Sound from ASTAR 32 inch LCD Television
There is more than one problem with. A it could be the main board that finally gave out. B the power board in your TV is not work, and now you can see a picture. Depending on how it's connect the screen could be burn out. but just what type of light comes on when you try to turn it on. if the green light comes on and stay on then it has to do with the picture not the power if you need help narrowing down the problem you can call 226-2211 My E Discounts. I'm a tech and we work with a Astar TV from time to time.
Astar LTV_3001
Hello Sir,
I need paciffic how's the TV defective (problem) so you have fix all the transistor and the capacitors then what happen next? still can't resolve your problem? unit still not right? call me at 323-767-6030 maybe I could help you through.
ASTAR 40" LCD / Pixel constantly on
No Sir,
pixel are come from the screen panel. All LCD TV have these pixel and some do shows and some don't. Also depending quality of the screen panel. (These should be counted panel defective) according the information through the LCD factory.
Astar Power Supply
Fixing the internal power no problem depending the power board it's burn or not. second thing is your LTV-32HBG TV with one HDMI connection or two HDMI connection? I know more about these Astar TV because I have work for the Astar co as an electronic technician before and I only give out such information how to repair these tv. so, call 323-767-6030 and I will help you go through with you problem by the phone.
No remote
I know some one can help you find these astar remote. just call number 323-767-6030.
Astar 32 in LCD
Have check internal power board? any way just call me at
323-767-6030 I will help you go through as much as I can to power up your tv.
Power
Hello Martha,
If you still have these astar tv please call 323-767-6030 I will help you find your problem.
I need a driver
hi go tru my computer property, hardware, device manager & display.unistall the display adapter & restart ur system
Astar 32" lcd tv
Has someone given this person the answer for remote code. I have the same problem. We must be able to check the serial number or call Astar Help Line. What happenen?
