20 Most Recent JVC GR-D240 Mini DV Digital Camcorder Questions & Answers
You'll need a Frame Grabber to transfer video off the tape to a TV using the A/V cable for the camera. Google Frame Grabber to find one that suits your budget.
JVC GR-D240 Mini... | Answered on Jun 09, 2015
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
JVC GR-D240 Mini... | Answered on Jan 22, 2014
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
JVC GR-D240 Mini... | Answered on Oct 26, 2011
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
JVC GR-D240 Mini... | Answered on Aug 11, 2011
You need a USB cable. Most miniDV cameras that take stills will have a small USB socket on the camera. These vary according to model. There is mini USB as well as Micro USB and other proprietary sockets. Usually the camera is supplied with the camera.
When the camera is connected to a Mac iPhoto should open automatically to transfer the photos.
JVC GR-D240 Mini... | Answered on Jun 30, 2011
Use Windows Movie Maker it should be installed as part of the Operating System.
A firewire cable is required. 4 to 6 pin for most Desktops or 4 to 4 pin for most Laptops.
JVC GR-D240 Mini... | Answered on Mar 20, 2011
JVC GR-D240 Mini... | Answered on Feb 18, 2011
Hi.
Safeguard mode error 03 is a traction problem. It means that the motor could not pull the tape. If possible remove the tape. With tape out, remove and reinsert the battery to reset the camcorder. Restart the camcorder and use a new cassette to test it.
Here the technical explanation from service manual.
If the tape does not eject, try removing and reinserting battery with cassette inside, then try again removing cassette.
If the error does not occur with new cassette, then the cassette that was inside is the problem.
If the error comes back with a different tape (test a new one), then the problem is the traction mechanics in camcorder, in that case the camcorder will need disassembling.
If the error is persisting, you can get a quote on repair calling JVC number listed on manual, or using a third part repair service like this one:Repair.
Regards.
Ginko.
JVC GR-D240 Mini... | Answered on Feb 08, 2011
JVC GR-D240 Mini DV Digital Camcorder Logo
51 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
obtain software gr d240 camcorder
  • Video Cameras
