20 Most Recent Dell W3707C 37 in. LCD Television Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dell W3707C 37... | Answered on Apr 12, 2017
If it is a projection screen you have to take it apart. First lay the tv face down on a bed then remove the screws that hold the back on. Be carefule some of the screws are hidden and most of them are torx bit. Please make sure you dont void any waranty by doing this! When you have all the screws out the flip it back over and carefully pull the face and screen off. This will allow you to clean it. DO NOT use anything but mild soap and water. I hope this helped.
Dell W3707C 37... | Answered on May 20, 2015
How do I take a part a my dell w3707c 37 in t.v.
a
Dell W3707C 37... | Answered on May 01, 2015
Anonymous,
You can click the links to view the manuals on how to resolve this issue.
http://www.manualslib.com/manual/227902/Dell-W3707c.html?page=40
Table of Contents
http://www.manualslib.com/manual/227902/Dell-W3707c.html?page=3
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Dell W3707C 37... | Answered on Mar 25, 2015
Backlight problem. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Dell W3707C 37... | Answered on Jul 17, 2014
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Dell W3707C 37... | Answered on Nov 02, 2012
Contact the authorized service center for Dell.
Dell W3707C 37... | Answered on Aug 26, 2012
I have exactly the same problem with my mac mini when I connect it to my Sony Bravia with an HDMI cable which works fine with my Apple TV. Sorry I don't have an answer yet!
Dell W3707C 37... | Answered on Nov 26, 2011
Boards: http://www.shopjimmy.com/catalogsearch/result/?q=Dell+W3707C
It can be on the center top of the LCD panel or center bottom depends on the version you have.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Dell W3707C 37... | Answered on Jul 13, 2011
Just make sure that the wall outlet you are using is actually live. Try plugging in a reading lamp to that socket to make sure it has power.
If power is good, then check where the power cord enters the back of the tv for a fuse holder.
If there is one there, then unplug the tv and replace the fuse with a new one.
Otherwise you might be looking at getting out your screwdriver and disassembling the tv to have a look at the main power supply circuit board.
I looked at the owner's manual located at the following link but they did not mention if the set had an easily accessible fuse there or not.
http://support.dell.com/support/edocs/systems/W3707C/en/index.htm
Good luck and keep us posted on how you are making out.
Dell W3707C 37... | Answered on Jan 21, 2011
This is a crazy set, I have the same one, and Dell does not support it, and most electronic places don't either You problem is the audio(sound) board, this has an IC on it that can't be found, I once found the board on ebay, but did not buy. Good Luck!
Dell W3707C 37... | Answered on Jan 14, 2011
Well I couldn't find one in my collection either. However if you can upload a high res image of the lock to imageshack.us and get me the link then I can tell you how to remove it. Also what are you trying to remove? Is it the back cover?
Dell W3707C 37... | Answered on Mar 12, 2010
Look on line at Encompass Parts Distrubtion or call them 1-800-638-3328
Dell W3707C 37... | Answered on Jan 04, 2010
Dell W3707C 37 in. LCD Television Logo
26 questions posted
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Televison & Video
Most Popular Question
yesterday while tv dell w3707c operating
  • Televison & Video
