20 Most Recent
Audiovox FPE3206 32 in. LCD Television Questions & Answers
FPE3206 - I have blue
The tv main Tuner signal board it is dead and it is the causes,if u have 2 burn surface mount resistors on it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole main Tuner signal board for the replacement.
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Audiovox FPE3206 HDTV - blown power supply-burnt
The manufacturer is the source for parts or call them and ask them if they have a part distributor near you or online for ordering.
You may also ask the local TV shop to order the part for you for a small shipping fee.
No screen
sound no picture
its the invertor board controls the backlighting
My 37inch lg lcd television was working this
The power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
MY TV TURNS ON BUT NO PICTURE OR SOUND I HAVE A
you could have bad capacitors in power supply.You can probably see the they normaly have flat top.If top is round like a bubble it is bad.This is common problem with flat panel lcd tv and monitors
Fuse and power supply look ok to the eye slight
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
Tv screen went black and no sound
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plaguePlease post back what you find. It sounds like at least you do have the 5V standby power supply working but the main supply is not getting the 'ON' command from the main board, or the power supply is gettin ght e 'ON' signal but failed to turn on.
Audiovox fpe2705 inverter board replacement
You need to verify first that you do have 24vdc feeding the inverter boards, if you do have 24vdc then we can be sure it is the inverter boards. The inverter board will have very small surface mounted fuses, check for that also.
