20 Most Recent
Konica Minolta magicolor 2500 Printer Questions & Answers
After paper jam printer displays error light and
1. Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Step 2
Turn off the printer.
3. Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. Step 6
jQuery(document).ready(function(){
jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg');
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. Step 7
jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg');
If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though.
8. Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Vertical lines of missing print
I'd certainly be swapping the fuser first although I know how expensive they can be and what a pain they can be to get at. You've tried everything else I would start with and as the text is smudging I'd certainly be testing the fuser next. Scott.
Problem with konica minolta paper margin
You don't have any solution but to increase the above margin to be equal as the bottom margin. To successfully print the pages, this printer need a larger bottom margin compared with the above margin. Just use the 'Center on page' option from your graphic application.
Multiple errors with 2 of these printers
Hi ntygrl,
Other than suggest you triple check if you have remove all the packing/locking tape around/inside the new printer, am afraid not much. This particular model before discontinued was prone to paper jamming and other mechanical issue (you probably heard it on the old one clacking and whirring noise).
Sorry but that's about it. Maybe you can try their customer support for repair/replacement of the new one. May I suggest a replacement (better with a newer model) even if you have to add a few more.
Good luck and kind regards.
