20 Most Recent
Garmin StreetPilot C530 GPS Navigator GPS Receiver Questions & Answers
Garmin does not read sd card
What size and type of SD card is being used?
The Garmin StreetPilot C530 will not support SD cards larger than 2GB or SDHC cards.
9/21/2011 9:38:08 PM •
Garmin...
Answered
on Sep 21, 2011
It says the gps is turned off
go into the settings and turn off simulator mode... or the device is dead. call Garmin to see what they can do 1800-800-1020
8/9/2014 4:37:44 AM •
Garmin...
Answered
on Aug 09, 2014
Can't save truck profile garmin 560 lmt
get a new unit... the street pilot series is outdated and it's a miracle that your unit is still working at all. Celebrate that you have gotten 10+ years out of that unit and go get your self a Dezl or RV unit
8/5/2014 6:57:12 AM •
Garmin...
Answered
on Aug 05, 2014
My Garmin will not stay on. It starts to come on then shuts off.
Hi Paulette,Many Garmin GPS units that only get powered by the car charger / cradle suffer from this problem eventually. The fix is pretty simple. You didn't include your model GPS, but I think this may help just the same:Connect the GPS to a computer's USB port, or AC adapter that has a USB port and leave on for 8 hours (or over night). Disconnect and and turn on again. If you have a Nuvi that has a spring return sliding power switch - slide and hold it in the on position for 15 seconds before letting go. It should power up just fine. You do not need to hold the power switch like this again to turn it on.If the GPS starts acting like this again, simply repeat the process as often as needed. Eventually, the internal battery will no longer be able to accept a charge and will require replacement.Good luck!
1/31/2012 10:08:44 PM •
Garmin...
Answered
on Jan 31, 2012
How to prevent Drive52 continually resetting itself ?
By 'resetting' you mean it switches off, and because it is connected to power, it boots back up. Do you have a SD Card in it?
I had trouble with a Nuvi 1350 with SD Card that had the whole USA Map on it, mine came with the Canada Map only. It would randomly turn off, so I decided to buy a Factory Refurbished Drive 50. I removed the SD Card and Reset the Nuvi and it worked perfectly after that.
The Drive 50 was also a bit flaky, and resetting fixed that as well.
You can back up your Favourites beforehand.
7/21/2023 1:33:43 AM •
Garmin GPS
Answered
on Jul 21, 2023
I have the Garmin etrex 20x and wish to calibrate the compass
I recently purchased a Garmin GPSMAP 78s
I had a lot of trouble calibrating the compass; I literally tried it hundreds of times without success. I also did a hard reset etc etc. Believe me I definitely tried everything possible but to no avail
I did contact Garmin but they didn't have an answer straight away for the problem
I have now sorted it as follows:
Do each step VERY SLOWLY, MUCH slower than you think you should
There are three steps to go through in calibrating the compass 1)Spinning the whole unit around flat 2)Flipping it over longitudinally and then 3) Flipping it over end to end. But remember do each step VERY slowly and go to the next step when prompted by the unit
This solved my issue. I can now calibrate my compass 9 out of 10 attempts
Hope that helps
7/16/2023 11:59:56 PM •
Garmin GPS
Answered
on Jul 16, 2023
Garmin nuvi 50LM cant access on mtp settings
To open the MTP settings on your Garmin Nuvi 50LM, you will need to access the device's menu. From the main menu, select the "Settings" option and then select the "System" option. From there, you should be able to access the MTP settings. If you are still unable to access the settings, you may need to contact the manufacturer for assistance.
1/29/2023 7:08:11 AM •
Garmin GPS
Answered
on Jan 29, 2023
Garmin 120 wont turn on
Hi Earl,
Sometime it could just be of aging. I have a 130, it was having similar problems, until i realized it was the screen not showing, but power on turning on. In your case, I probably probably try a hard factory reset as follows:
To perform a master reset:
- Turn off the device.
- Press the PAGE, ENTER2, and POWER buttons simultaneously.
- Release all buttons once the Do you really want to erase all user data? message appears.
- Select Yes.
hope this helps!
Kevin
12/8/2022 9:55:29 AM •
Garmin GPS
Answered
on Dec 08, 2022
