20 Most Recent
Astar LTV-40HBG 40 in. LCD HDTV Questions & Answers
The picture from the cable tv will only stay on
Check if this happens using other sources of signal such as a DVD player or a playstation. This could be a problem with the port or the cable that the signal uses to get to your TV. If you can use a different cable or test using a different TV just to make sure.
On my tv it keeps saying
the tv needs to be reset.the main board circuit is got short by any of its major component getting blowed or getting weak.
the board needs to be checked.
try this reset first
for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Need a pass word for
Did you lock yourself out? or are you trying to reset the password? need more detailed info.
Astar screen stays white when turned on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
