20 Most Recent Gateway CX2619 Notebook Questions & Answers
How to replace keyboard
12/31/2011 1:22:14 AM • Gateway CX2619... • Answered on Dec 31, 2011
My Gateway laptop model CS2619 gets stuck on the
Reformat is an option
3/12/2011 4:05:52 PM • Gateway CX2619... • Answered on Mar 12, 2011
How to fix power jack, new power supply, new
You most likely need a new motherboard in most cases, or a new power jack device. Either way, contact your local computer repair and let them see if they can fix it, due to the matter of this being more than a 1 day fix and having to get parts.
3/1/2011 2:20:17 AM • Gateway CX2619... • Answered on Mar 01, 2011
Gateway CX2619 I heard it shut down in the middle
Try removing the battery and leaving for 5 mins. replace battery. This can reset a stuck power supply
11/30/2009 4:18:56 PM • Gateway CX2619... • Answered on Nov 30, 2009
Loose Hinge on my Gateway cx2619
first try tightening the hinge which means dissamly of the laptop, or check ebay or gateway parts for replacement hinges.
10/12/2009 5:48:27 PM • Gateway CX2619... • Answered on Oct 12, 2009
Gateway Computer, model CX2619 will not start
have you done any upgrades
EI memory or windows
1/22/2009 2:37:59 AM • Gateway CX2619... • Answered on Jan 22, 2009
NTDL ERROR
You did not leave any hints on what was done leading up to this. Could be that you have something plugged into a usb or cd rom slot and it is trying to boot to it. Could be you put a drive in that was not fully erased. Could be your boot file is messed up...if that is the case, put windows disk in and see if it can do a repair.
5/17/2014 11:56:18 PM • Gateway CX... • Answered on May 17, 2014
GETTING NTDL ERROR
If you are able to see the "NTLDR is missing" error on your screen, your motherboard works. If your laptop was working before and suddenly shows this error, it could be that the file system is damaged. You could check this help page with plenty of information how to fix NTLDR problems: http://pcsupport.about.com/od/findbyerrormessage/a/ntldrmissingxp.htm
5/17/2014 8:20:20 PM • Gateway CX... • Answered on May 17, 2014
Forgot pass word.
if u forget bios password please reset it .if u forget system password try to login from administrator if you already sing in with administrator please change the Os .
9/18/2013 2:58:51 AM • Gateway CX... • Answered on Sep 18, 2013
I have the application SuperSU the free edition on my phone and everytime I try to use it to root my phone forwards me to an address on Chrome the simply says 502 bad gateway
you can use kingroot to root your phone. and some root apps might harm yor os i suggest you not to root your phone
3/1/2024 4:28:21 PM • Gateway... • Answered on Mar 01, 2024
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor. The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port. I hope this helps. Cindy Wells
1/18/2024 10:32:24 PM • Gateway... • Answered on Jan 18, 2024
I have a gateway Zx4931 and the power button is not working. Do I need to replace the power button or can I reconnect the wires?
Re connecting the wires may work without issues.
12/26/2023 5:46:39 PM • Gateway... • Answered on Dec 26, 2023
Do i need a driver for old gateway gmax2000 speakers connected to an old acer-based home built pc my nephew gave me?
No you don't need a driver. These are very plain powered speakers that come with a mains adapter and a lead with a 3.5mm stereo jack at both ends. Plug one in the speaker and the other into the headphone jack on the front or the speaker socket on the back which will either be a socket on the motherboard, or if your son put a sound card in the computer, it will be in a sound card. If it doesn't play straight away, go into Settings - Audio and make sure the sound card or the On-Board Audio is enabled. This shows the cable https://picclick.com/Vintage-Gateway-2000-ACS41-Altec-Lansing-Multimedia-Computer-314990339798.html#&gid=1&pid=1 More here https://www.google.com/search?q=gateway+gmax2000+speakers ..
11/29/2023 12:20:06 AM • Gateway... • Answered on Nov 29, 2023
WATTS REQUIRED FOR GATEWAY LAPTOP NV55C
110 watts for the power supply.
11/21/2023 1:16:48 AM • Gateway... • Answered on Nov 21, 2023
Wiring diagram for LX6200-01
10/30/2023 11:58:58 PM • Gateway... • Answered on Oct 30, 2023
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do. First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button. Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button. Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation. I hope this helps!
3/14/2023 5:41:18 PM • Gateway... • Answered on Mar 14, 2023
I have a Gateway Laptop that on startup only goes to the configuration screen. It won't boot Windows at all
They deleted the Operating System by deleting their own stuff Docs, images, Saved Links etc. and also everything in Windows System probably in spite. You need to reload the operating system (Win 11) from fresh. Charge them from their final pay check, or ask IT to do it.
3/1/2023 1:19:14 AM • Gateway... • Answered on Mar 01, 2023
2answers
Gateway / Packard Bell EASYNOTE MS2291 Laptop will not start.
Question edited for a lot more clarity, FULL 'make, model (what it is)'. Question moved from 'Power Computers'. Connect a computer monitor to the port on the back. When I Google the model number the first thing that shows is Replacement LCD Screens for it which leads me to believe there is an issue with them. There is three parts to the display, the video card section, the exciter module and the screen itself. It needs correct diagnosis, or buy a new one now you have reset it clean, if that is what you mean by 'hard restart'? You might mean 'hard boot', power off and back on without proper shutdown. That is bad for the OS. https://www.google.com/search?q=Model+MS2291 Keyboard shortcuts for shutdown
How to Shut Down or Sleep Windows 10/11 With a Keyboard ...
https://www.makeuseof.com > Windows 1. Use the Power User Menu Shortcut · Press U again to shut down Windows. · Hit the R key to restart. · Press S to put Windows to sleep. · Use H to hibernate. · Hit ... Sleep Mode Issues · ‎Establish a hotkey · ‎Guide to hibernation on.....
2/26/2023 8:34:30 PM • Gateway... • Answered on Feb 26, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
  1. Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
  2. Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
  3. Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
  4. Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
  5. Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM • Gateway... • Answered on Feb 26, 2023
Gateway CX2619 Notebook Logo
8 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CX Gateway
  • CX Gateway
Most Popular Question
replace keyboard
  • Computers & Internet
