20 Most Recent Sharp LC-32D41U 32 in. LCD Television Questions & Answers
The tv universal remote have it limition mostly only functions for the basic only like power,channel up/down,volume up/down only.The inter menu functions of the tv and changes it setting and adjustments.Require a tv original remote.Try wesite like Remotes.com to buy the tv original remote to used.
Sharp LC-32D41U... | Answered on Aug 28, 2011
The backlight inverter board may be going out, or the power supply for the inverter board may be going out, it may get worst and causes more damages.
Sharp LC-32D41U... | Answered on Nov 07, 2009
Simple modification to inverter board will take care of this problem. Any sharp authorized service can perform this mod
Sharp LC-32D41U... | Answered on Oct 25, 2009
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Sharp LC-32D41U... | Answered on Jul 20, 2009
you need to replace the audio/video apparatus. on the back of the tv you open the right side panel below and disconnect the thing looks like a transformer can't miss it plug it in and if the green light don't come on than it is burnt out, I took it to best buy and they checked it out and confirmed that it is burnt out. it is part that connects to the outlet. I am trying to find out how much it costs i did some months back just don't remember the price. So I am investigating on this where i can buy it cheap.
Sharp LC-32D41U... | Answered on Jan 21, 2009
Menu on remote and make sure you have it on wide screen or 16 to 9
Sharp LC... | Answered on Jan 17, 2019
Hello
If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them.
For any help or support just visit us: www Roku Com Link
Sharp LC... | Answered on May 26, 2018
When you say WD box, do you mean a Western Digital Hard Disk Drive? If so, get a Solid State Drive (SSD), and connect it via USB3.
The HDD or the USB connection is not fast enough to keep up with the required speed of the video.
If you mean something else, please add details.
Sharp LC... | Answered on Dec 05, 2017
Check the high voltage circuit on the board that has the 120 volts input. The high voltage should be close to 400 volts - nothing less than 390 volts. The capacitor is failing to hold the voltage and needs to be replaced.
Sharp LC... | Answered on Oct 29, 2017
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
Sharp LC... | Answered on Dec 16, 2016
Look for it at its bottom side [stand]
Sharp LC... | Answered on Sep 26, 2016
Sharp LC-32D41U 32 in. LCD Television Logo
Popular Tags
11 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
sharp lc 32d41u
  • Televison & Video
