Troubleshooting & Support
Hot Topics:
Problems & Solutions
Will not print nor delete printing job
great to hear!
IT SAYS FREE SUPPORT FOR YOUR PRINTER---WHY WOULD
go to start >> click on run>>type "cmd" without quotes in box command prompt opens type> net stop spooler and hit...
i lost my cd software to install my hp deskjet...
go to the following link and select your OS:...
I had a paper jam in my HP 2330 printer. I
Hello there You may not see a paper jam. This may work for you, it has worked for many here I given this advice so gave it a try it could...
asking to change magenta cartridge. Have changed
press and hold the power button of your printer for 20-30 sec and make a copy if still the same issue occurs the proiblem is with the...
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other...
HP Deskjet 2330 problem
1)right click the my computer icon 2)click properties and then click hardware n go to device manager. 3)uninstall all usb ports...
ink cartridges
You need both cartridges to run your printer.
dell 1600n
This model Dell printer can connect to your computer by -Hi-Speed USB cable, orover your network using Ethernet 10 Base-T/100 Base-TX
how to add officejet K80xi in Toshiba sattellite...
Hello,Go to start menu bar then devices and printers click on it then choose add a printer then insert your printer cd into cd drive then...
set up guide for HP officejet 5600 all-in-one
Take your pick from here.
need users manual for hp photosmart c4680 printer
HiDownload the manual from the link below.h10032.www1.hp.com/ctg/Manual/c02240492.pdfHope it helps.
hp C6180 printer will not copy or scan
I have the same printer, and I just re-installed it a few days ago. I had just performed a clean re-installation of my Windows operating...
printer wont connect to network and now won't...
Dear, Model no not mentioned, If its not printing through net work or USB it might be formatter faulty,,replace it..
I got a pop-up saying there was updated software....
You need to go into your printer setting and make sure that your printer is set to defualt
Unsolved Problems
I have checked all of the plugs but my printer
I have checked all of the plugs but my printer still won't turn on.
Cannot install HP 2330 printer
Cannot install HP 2330 printer from available download of install drivers from website. I get error message "no...
My HP 2330 is slow to print a pdf file
My HP 2330 is slow to print a pdf file how can I speed up the printing process?
losing bottom 1/2
losing bottom 1/2 " of printing on a word document. 2330
moved to another location and printer won't...
This was a gift about a year ago for Christmas. It had worked beautifully until I moved. Now I cannot get it to work on...
Manuals & Guides
TopDo you have a manual for HP Deskjet 2330 InkJet Photo Printer? - Upload it to FixYa!
Upload a manual for HP Deskjet 2330 InkJet Photo Printer
Specifications
TopKey Features
Full Product Name:HP Deskjet 2330 InkJet Photo Printer
Technology (Detailed):Thermal Inkjet
Black Print Speed:12.5 ppm
Output Type:Color Printer
Max Resolution (BW):1200 x 1200 dpi
Color Print Speed:12.5 ppm
Printer Type:Digital Photo
Technical Features
Form Factor:Desktop
Duplex Printout:Manual
Monthly Duty Cycle:999 and less (Low Output)
Monthly Duty Volume:500 Pages
Language Simulation:LIDIL
Media
Media Type:Transparencies
Media Type:Plain Paper
Media Type:Envelopes
Media Type:Cards
Media Type:Labels
Media Type:Inkjet Paper
Media Type:Photo Paper
Media Type:Iron-On Transfers
Media Type:HP Premium Media
Max Media Size:Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity:100 Sheets
What's your problem?
Fix-O-Meter
729
729 people have viewed this product
- 14 people asked about this product.
- 8 people found solutions for this product.
- 1 person has added this product.
How to resolve...
Getting help...
Printer reset
