20 Most Recent
Lexmark C532dn Laser Printer Questions & Answers
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
How and where do I install memory cards?
www.
lexmark.com/publications/pdfs/2007/.../v7649663_en.pdf
LexmarkSetting up the printer as a copier only. ... Installing the optional XPS driver (Windows Vista users ...... Do not pinch the power cord between objects such as furniture .....Transfer photos and documents from a memory device to the computer over .... cSelect the print quality, the number of copies to print, the type of paper to be ...
www.
lexmark.com/publications/pdfs/2007/.../v7677571_en.pdf
LexmarkSetting up the printer as a copier only or fax only. .... Installing the optional XPS driver (Windows Vista users only). .... Information you will need to set up the printer on a wireless network................................................... ...... Inserting a memory card .Missing: c
How can I fix the missed OCR in Lexmark x3550 printer
Quite often the OCR portion is a third party software product and Lexmark cannot offer it as a download. Your best bet is to contact Lexmark customer support to see if they can help, but be advised they may want to charge for the disk.
