20 Most Recent
Xerox Phaser 6180N Laser Printer Questions & Answers
I have xerox works center pro photo copier model
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
How to turn off replace fuser on display on xerox 6180
The message is caused by the fuser having had 100,000 pages or so through it.
It will be pretty much worn out, and should be replaced.
The transfer belt also has a similar pagecount limited life, and also the pickup/separation/transport rollers would benefit from replacing (they can get 'flat spots' on them
Water mark on page
If these are at regular intervals across the page AND down the page , with a spacing of about 1" - read on..
They are caused by a component in the toner cartridge.
Originally the cleaning roller was a plain roller, but at some time the 'bean counters' decided they could save a tiny bit of money on each cartridge by using a spiral foam roller instead. The foam also seems to be of a different type, and doesn't age well.
There are two solutions.
1. Replace the cartridge that is producing the coloured squiggle/
2, dismantle an OLD cartridge and if it has a plain (non-spiral) foam roller, swap that (along with it's supports - the new type are a different size).
Either of the above will cure the problem, but a new replacement cartridge may also show the problem in time, as it WILL have the spiral cleaning roller.
Xerox phaser 6180 smudges
If these look like a little squiggles, repeated across the page AND down it, at about 1" spacing.
They are cause by a component in the toner cartridge.
Xerox 6180mfp repeating pattern
BLUE WAVES LINES COME OUT WHEN I PRINT AN IMAGE
These will probably look like a little squiggle repeated across the page AND down it at regular intervals.
Xerox Phaser 6280 Y CRUM ERROR
The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
Phaser 6180 prints little black smudges on every
These will probably look like a little squiggle.
Phaser 6180 streaking
If it's just one colour, it's usually THAT colour Toner cartridge that's the cause .
Replace cyan
Your cyan print cartridge has run out.
To replace you need to order either
113R00719 standard capacity cartridge or,
113R00723 high capacity cartridge.
The standard gives you approximately 2,000
prints at 5% coverage and the high capacity
gives you 6,000 prints at 5% coverage.
Hope this helps.
