20 Most Recent Lexmark C534dn Laser Printer Questions & Answers
If that is dotted lozenges probably the defect in this voltage source or the last case in the fuser unit. Try changing the font for one that has know works.
Lexmark C534dn... | Answered on Dec 06, 2013
On laser printers, this can be caused by the charge roller or the print head. I would first look at cleaning thoroughly the charge roller (this is the roller that goes in to the Toner cartridge when you close the lid.
Use soapy water and let dry COMPLETELY before reinstalling. Or just replace it (better choice really)
This can also be caused by the print head and the fuser. so if the charge roller doesn't fix the problem, start looking there
Lexmark C534dn... | Answered on Jun 16, 2011
This error message appears on the printer screen when the printer thinks the wrong toner cartridge is installed. To clear it or identify a service requirement, follow the steps below. NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
  1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
  2. Make sure the correct toner cartridge is installed for this printer model.
    1. Check Lexmark for a list of compatible cartridges for your printer.
    2. If the wrong toner cartridge is installed, remove it and install the correct one.
  3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
    1. Turn off the printer.
    2. Reseat the toner cartridge.
    3. Close the lid.
    4. Power the printer back on and check the display.
  4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
    1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
    2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
  5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
Lexmark C534dn... | Answered on Feb 15, 2011
This is common. Just delete the first print job in the Que and the rest should start printing. The first one would be the one on top of the list. This happens when for some reason a print job fails. Then it holds up everything behind it.
Good Luck and Thank You for using Fixya.
WheatlandServices
Lexmark C534dn... | Answered on Dec 22, 2010
toner is going to empty, for instant solution take out toner cartridge and shake it for some time, then put it back to printer it will resolve your problem for a while but ultimate solution is replacement or re-fill.
Lexmark C534dn... | Answered on Nov 05, 2010
Carefully and thoroughly clean the rollers with rubbing alcohol and cleaning cloths.
Lexmark C534dn... | Answered on Mar 06, 2010
I have also had this problem which I solved by changing the photoconductors of the colours shown.
you can try this.I am not sure if that is the best solution but it solved my problem
Lexmark C534dn... | Answered on Jun 18, 2009
use deep head clean
PDF]2600 Series User's Guide - Lexmark
www.lexmark.com/publications/pdfs/2007/.../v7649663_en.pdf
LexmarkSetting up the printer as a copier only. ... Installing the optional XPS driver (Windows Vista users ...... Do not pinch the power cord between objects such as furniture .....Transfer photos and documents from a memory device to the computer over .... cSelect the print quality, the number of copies to print, the type of paper to be ...
[PDF]5600-6600 Series User's Guide - Lexmark
www.lexmark.com/publications/pdfs/2007/.../v7677571_en.pdf
LexmarkSetting up the printer as a copier only or fax only. .... Installing the optional XPS driver (Windows Vista users only). .... Information you will need to set up the printer on a wireless network................................................... ...... Inserting a memory card .Missing: c
All Products ' Printers & MultiFunction ' Lexmark CX410de ...
Lexmark C Office... | Answered on Jan 10, 2016
Quite often the OCR portion is a third party software product and Lexmark cannot offer it as a download. Your best bet is to contact Lexmark customer support to see if they can help, but be advised they may want to charge for the disk.
Lexmark C Office... | Answered on Dec 20, 2014
It could be one of 3 things. I assume you already tried replacement of the fuser. IF ... that didnt work do the LVPS then the system board last. Also check the 115/220 switch on the LVPS.
Lexmark C Office... | Answered on Sep 15, 2014
Lexmark C534dn Laser Printer Logo
22 questions posted
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C Lexmark
  • C Lexmark
Most Popular Question
when turned printer only displays
  • Office Equipment & Supplies
