FixYa.com
NEC LCD2190UXi  LCD Monitor
All Products > NEC > Monitors
Problems with NEC LCD2190UXi LCD Monitor?
Search inside NEC LCD2190UXi LCD Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for NEC LCD2190UXi  LCD Monitor RSS Feed Post a New Problem
When it's turned on, the light on my...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be...
1 Solution
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
I was tring to Connect Two Computers to...
I was tring to Connect Two Computers to One Monitor, but i didnt get it, does someone know how to do so?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
Getting More Brightness/Contrast ?
Im using an HP 90 (D2842) 19" monitor and find all movies and pictures to be too dark to view. I have the...
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
MONITOR REPAIR HELP
Hi I would like to appreciate for your help I have got an Acer monitor model G781 CRT Type its switching power...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC LCD2190UXi  LCD Monitor RSS Feed Post a New Problem
ViewSonic VA720 LED Monitor
My monitor flashes the green light where you turn it off and on the screen is black. also am unable to turn monitor off....
Post a Solution
fuse blown
tried replacing fuse 2.5ah on power pcb. blows immediately. Can't get schematics or support.
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio4:3
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness250 cd/m
Dot Pitch0.27 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time20 ms
Viewable Picture Size21.3 in.
Technical Features
Form FactorDesktop
Digital Video Input StandardDVI-D
Synchronization Range - Horizontal31.5 - 91.1 kHz
Max. Viewing Angle - Horizontal178
Max. Viewing Angle - Vertical178
Native (Recommended) Resolution1600 x 1200
Resolutions supported1280 x 1024 · 1600 x 1200 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 1152 x 870 · 720 x 400 · 640 x 400
Synchronization Range - Vertical50 - 85 Hz
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
