20 Most Recent Konica Minolta magicolor 2490MF Laser Printer Questions & Answers
check the tray one paper empty senor blow out with air is the paper acturator broken that the device that would lay on the paper when its out of paper the sensor will drop far enough to tell the printer tray one is out of paper miss feed are the rollers are dirty and or need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Feb 25, 2018
have tech do it requires a lot of parts to remove
Konica Minolta... | Answered on Jun 26, 2016
please explain what is Ian and connect to what
Konica Minolta... | Answered on Jan 15, 2016
check the scanner lock on the machine or have the scanner replaced.
Konica Minolta... | Answered on Jan 10, 2016
where does it jam? what caution?
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
Push the Display button
This will show the toner levels.
Push the down arrow to toggle through the copy counts (B/W & colour, copies, faxes, scans etc).
If you are looking for the instructions in a PDF manual search for "counter" instead of "meter".
Konica Minolta... | Answered on Mar 11, 2015
i have a bizhub C350 and has this error code coming once power ON the error code C-12CC..please if any one has faced the problem i will appreciate your help....
Konica Minolta... | Answered on Oct 26, 2014
Firmware update required...
Konica Minolta... | Answered on Jan 16, 2014
You need to give the machine an IP address.
Konica Minolta... | Answered on Nov 15, 2013
What kind of connection do you have? From PC to printer?
USB or LAN?
Konica Minolta... | Answered on Oct 07, 2013
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Konica Minolta... | Answered on May 21, 2013
If you want to use the toner cartridge after the printer decides that it's empty, you can do it by going into the Machine Settings in the menu, and option 8 (at least on my Magicolor 2590MF) says "Toner empty stop?". Just change that to NO, and you're set to go.
Konica Minolta... | Answered on Apr 02, 2013
Konica Minolta magicolor  2490MF Laser Printer Logo
65 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Magicolor Konica Minolta
  • Magicolor Konica Minolta
Most Popular Question
connect konica minolta magicolor
  • Office Equipment & Supplies
