20 Most Recent
Toshiba Satellite M105-S3084 Notebook Questions & Answers
Hi team, I have toshiba
The CMOS battery most likely needs to be replaced. This can be a daunting task even for a pro. The CMOS battery is most likely a CR2032 watch battery that you can pick up at almost any computer repair shop or even a **** store in the battery section... even at a home supply store where they have replacement batteries for garage door openers.
However, getting to the battery, which is mounted on the motherboard can be very difficult to get to and should only be attempted by a professional repair shop.
My advice? It's probably time to just toss this laptop to the recycle guys (you might want to pull out the hard drive first and mount it into an external case if you want to retrieve files from it... or destroy it with a drill if you don't).
To illustrate just how difficult it can be with this model of Toshiba Satellite, I've included a video link. I think you'll get the picture.
https://www.youtube.com/watch?v=AfHAbAcMKlE
9/20/2017 5:05:14 PM •
Toshiba...
Answered
on Sep 20, 2017
When starting the laptop the
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. It can also be due to the fact that the memory card slot is not contacting . Please remove and wipe clean the contact points and reset. trying with a new memory card is the other option before we can suspect the motherboard.
If the Pc boots but tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Thank You for using Fixya
9/21/2011 4:57:30 AM •
Toshiba...
Answered
on Sep 21, 2011
After the change of cmos
Hi gavossevou...
You will need to start your computer in the "Safe Mode", you do this by tapping F8 while the computer is starting up.
Once the computer has started, select "Safe Mode".
Once you are in the safe mode, then you will double left click on "Start">Control Panel>User Accounts>Change an Account.
Now you can change your password,delete the account,etc.
Please take time to rate me
8/16/2011 7:33:28 PM •
Toshiba...
Answered
on Aug 16, 2011
Cant get pass bio screen on satellite m105-s3084 toshiba
The Toshiba BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work. There is a hardware hack solution (a dongle) to remove the password.
Buy a 25 pin male D Sub connector and join the following pins together by soldering wires to these pins. Make sure the wires do not short against each other. The pins are numbered on the connector.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle into the printer port of your laptop and power up the laptop. Press F2 function key to get into the BIOS and then remove the password. Your laptop should boot up without the password and you can remove the dongle.
7/4/2011 9:07:52 AM •
Toshiba...
Answered
on Jul 04, 2011
Bios password
This is a know issue with Toshiba laptops,
- Try the passwords listed here.
- If that doesn't work, you will need to send your laptop in to Toshiba, they will charge you if you are not under warranty, unfortunately, they do not reveal the master/reset password or procedures to others.
7/4/2011 8:06:02 AM •
Toshiba...
Answered
on Jul 04, 2011
The sound on my satellite m105-s3084 stopped working
Go to device manager, if the sound card has a yellow exclamation point near it, then the driver is at fault. You can simply reinstall the driver or remove the sound card and restart the computer. Windows will discover the sound card and install the driver
5/2/2009 2:38:59 AM •
Toshiba...
Answered
on May 02, 2009
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
