20 Most Recent Olympus Mju 725 SW Digital Camera Questions & Answers
Press the MENU button. Select the wrench-and-hammer icon. Select the clock icon.
If you need a manual, you may download a copy from here.
Olympus Mju 725... | Answered on Oct 24, 2012
Its seems lens got stuck in the barrel due to external shock caused, Try out following steps-
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once's or twice then it will stuck again.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else contact Olympus, your camera need to be disassembled to get at the focusing ring at Service Center .
I hope this will solve your problem
Thanks..!!
Olympus Mju 725... | Answered on Jul 04, 2011
I've gone through the manual, and i don't think you can. Many simple point and shoot cameras have just one fixed aperture. In the manual, the only thing i found was on page "10. P (Program auto) The camera automatically sets the optimum aperture value and shutter speed for the brightness of the subject."
Olympus Mju 725... | Answered on Apr 08, 2011
If it is a raised button try alcohol on a qutip to clean around the button or compressed air in the can. Hope it helps.
Olympus Mju 725... | Answered on May 05, 2010
kindly download the manual from the below link....
http://www.olympus.co.uk/consumer/208_manuals.cfm?prodID=P_N2525892
a very helpful rating is appreciated for answering ur query....
Olympus Mju 725... | Answered on Aug 18, 2009
Try to dismantle it and fix the shutter yourself before paying for repair.
Olympus Mju 725... | Answered on Jun 09, 2009
Connect your camera to PC with Windows XP or Vista via USB, open MyComputer and there should be a camera, which appear as new disk, open it and delete any image you need!
Olympus Mju 725... | Answered on Feb 15, 2009
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Olympus Mju 725... | Answered on Feb 12, 2009
Go to this web site find your camera select it. Then go to support then download the manual.
http://www.olympusamerica.com/cpg_section/cpg_digital.asp
Good Luck
Please rate FixYa!
Olympus Mju 725... | Answered on Dec 19, 2008
Well I know what the review says about underwater to five meters http://www.ephotozine.com/article/Olympus-Mju-725SW
but I would take it with a pinch of salt frankly.
You could get onto Olympus and tell them you know- 'You said I could take it under water - now it wont work' - They may replace it
Olympus Mju 725... | Answered on Jul 19, 2008
The the Manual to ensure a setting has not been cancelled -there is more comprehensive manual on the CD. When you say mut do you mean play back on camera or on computer? If the latter check out the computer sound system.
Olympus Mju 725... | Answered on Sep 22, 2007
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Olympus Mju... | Answered on Aug 09, 2013
Search on Google will give you several options
Olympus Cameras | Answered on Sep 09, 2019
Search for it on Google, or contact Olympus direct.
Olympus Cameras | Answered on Jul 22, 2019
Olympus Mju 725 SW Digital Camera Logo
22 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Mju Olympus
  • Mju Olympus
Most Popular Question
lens opening but not shutting
  • Cameras
