20 Most Recent
Amana 26 cu. ft. Side-By-Side Refrigerator, ASD2628HE Questions & Answers
Plug in frig starts cooling will make a thin layer
That problem may take a little work finding but that is no problem if you can pull away from the wall and unplug. Then remove the lower cover that covers the compressor area so you can feel the top of the compressor. Feeling the top of the compressor tells me several things like if it has been running all this time or if very hot it will tell me that the compressor has been short cycling. Compressors short cycle for a few reasons and one is the start components photo #8 and #4 in this photo here=>
ASD2628HES_COMPRESSOR_Components Another reason may be the evaporator fan or the condenser fan #20 in the photo link above are not staying on or there is an airflow restriction. When the compressor runs there should be a good steady flow of warm air from below the refrigerator. That warm air is the warm conditions being removed from inside your refrigerator. The most likely reason for this is the start relay/overload or number 4 in the photo has become defective. That is this=>
Relay Overload with Start Capacitor
With that part out and able to get the=>
65889-4 15uf run_capacitor
out I would carry the run capacitor to a local refrigeration dealer and ask if they would test your run capacitor for free. I will be here if you should have questions beyound what I have mentioned here today, Thanks, Sea Breeze
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
- Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
- Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
- Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
- Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
- Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM •
Amana...
Answered
on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM •
Amana...
Answered
on Jan 14, 2023
