Samsung HP-S5033 50 in. HDTV-Ready Plasma Television
Problems with Samsung HP-S5033 50 in. HDTV-Ready Plasma...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Samsung HP-S5033 50 in. HDTV-Ready...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Samsung HP-S5033 50 in. HDTV-Ready Plasma Television RSS Feed
View More Results for Samsung HP-S5033 50 in. HDTV-Ready Plasma Television
Questions and Unsolved Support Problems
Unsolved Problems for Samsung HP-S5033 50 in. HDTV-Ready Plasma Television RSS Feed
Answer
I have a Samsung HP-T5054. When you turn it on it looks like black clouds at first and then they go... (More)
Answer
I have also read where I can replace all the capacitors on the power board (around 25?) but I... (More)
Answer
the picture goes blank in the top half of the screen intermittently and sometimes the whole screen... (More)
Answer
The picture on my Samsung HP-S5033 Plasma TV is fine but I don't have any sound from the internal... (More)
Answer
hello, i have samsung hp-s5033 plasma tv the problem it's has great sound, change channes, but the... (More)
Find a Manual
Samsung HP-S5033 50 in. HDTV-Ready Plasma Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Lamp vs Ballast
This is to help explain the short lives of Lamps. WARRANTY: If a lamp fails within the first year replace Lamp and Ballast. If Lamp explodes do not... written by BIG IRISH
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
LCD Flat Screen Common Problems
Have you ever wanted to know what causes a nice LCD to give out so soon? Poor electronics components such as Capacitors. I will tell you how to spot a... written by rulds2008
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Samsung HP-S5033 50 in. HDTV-Ready Plasma Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Samsung HP-S5033 50 in. HDTV-Ready Plasma Television
Write a review:
Rate this product:
Would you recommend the HP-S5033 50 in. HDTV-Ready Plasma Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Samsung HP-S5033 50 in. HDTV-Ready Plasma Television
Key Features
Screen Size
50 inch
Contrast Ratio
10,000:1
Digital TV Standard
HDTV-Ready - Requires separate receiver to view HDTV signals. · HDTV-Ready Television
Flat Panel Type
Plasma Television
Display Resolution
1366 x 768 pixels
HDCP Support
With HDCP Support
Connectors
Rear Input Connectors
S-Video x 1 · Component x 2 · 1 x D-Sub (RGB PC) · HDMI x 2
Front Input Connectors
Audio (Mini Jack) x 1 · S-Video x 1
Display Capabilities
Built-in Tuner
NTSC
Digital TV Standard
Broadcast Format Displayed
480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Native Aspect Ratio
16:9
Image Quality
Brightness
1300 cd/m
Viewing Angle
175
Samsung Contact Information
Main support number1-800-SAMSUNG
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
