JVC LT-40FH97 40 in. HDTV LCD Television
Problems with JVC LT-40FH97 40 in. HDTV LCD Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for JVC LT-40FH97 40 in. HDTV LCD Television RSS Feed
View More Results for JVC LT-40FH97 40 in. HDTV LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for JVC LT-40FH97 40 in. HDTV LCD Television RSS Feed
Answer
Faint dark Horizontal lines on LCD screen which become worse when se has been on for a long time.... (More)
Answer
When I turn it on I have sound, but no picture... not even the display.
Answer
I have an LCD flat screen JVC. Came home from the movies and now... sound but no picture... not even... (More)
Answer
tv says unusable signal the signal type is set on cable i tried the dvd and still same thing
Answer
This TV was brought from Japan, it arrived in excellent condition, when the moving company first... (More)
Find a Manual
JVC LT-40FH97 40 in. HDTV LCD Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
How to test an infared remote control device
How can I tell if my remote is working? You could invest in an infared detector pen or device that will detect the infared signal or you could use a... written by premtech
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Vizio Factory Menu
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV. Here's how to... written by TechNerd
My LCD TV has sound but no picture.
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input. Try unplugging... written by ginko
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV. Check cable connection, and try using a different cable, video signal is... written by ginko
Help FixYa, Help you and help others. Share your User maunals and service...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Dish Network Television Remote Codes
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the... written by stoneheaded
Info on replacing polaroid caps
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After... written by prowler21
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for LT-40FH97 40 in. HDTV LCD Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the JVC LT-40FH97 40 in. HDTV LCD Television
Write a review:
Rate this product:
Would you recommend the LT-40FH97 40 in. HDTV LCD Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for JVC LT-40FH97 40 in. HDTV LCD Television
Key Features
Screen Size
40 inch
Contrast Ratio
1,000:1
Digital TV Standard
HDTV - HDTV receiver is integrated. · HDTV Television
Flat Panel Type
LCD Television
Display Resolution
1920 x 1080 pixels
HDCP Support
With HDCP Support
LCD Response Time
8 ms
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Dimensions
Depth
4.63 in.
Height
26.5 in.
Width
39.38 in.
Weight
55 lb.
Warranty
Overall Warranty
1 Year
Connectors
Rear Input Connectors
RF x 1 · Component x 2 · S-Video x 2 · Composite x 3 · Audio (RCA) x 3 · HDMI x 2 · FireWire x 2
Display Capabilities
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Broadcast Format Displayed
Native Aspect Ratio
16:9
Remote Control
Remote Control
Universal
Illuminated Remote
Illuminated
Audio Features
Audio Type
Surround
MTS Stereo
SAP / MTS Stereo
Screen Text
Closed Caption on Mute
Without Closed Caption On Mute
Image Quality
Comb Filter
3DYC / 3D Digital
Brightness
500 cd/m
Viewing Angle
178
Adjustable Color Temperature
With Adjustable Color Temperature
JVC Contact Information
Main support number(800) 252-5722
Email supportproinfo@jvc.com
Describe your problem:
Top Flat Panel Televisions Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
