20 Most Recent Sharp LC-37DB5U 37 in. HDTV LCD Television Questions & Answers
The power supply is failing. The clicking sound indicates the power supply is attempting to start but can't.
Sharp LC-37DB5U... | Answered on Jan 14, 2014
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Sharp LC-37DB5U... | Answered on Jan 07, 2013
Menu on remote and make sure you have it on wide screen or 16 to 9
Sharp LC... | Answered on Jan 17, 2019
Hello
If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them.
For any help or support just visit us: www Roku Com Link
Sharp LC... | Answered on May 26, 2018
When you say WD box, do you mean a Western Digital Hard Disk Drive? If so, get a Solid State Drive (SSD), and connect it via USB3.
The HDD or the USB connection is not fast enough to keep up with the required speed of the video.
If you mean something else, please add details.
Sharp LC... | Answered on Dec 05, 2017
Check the high voltage circuit on the board that has the 120 volts input. The high voltage should be close to 400 volts - nothing less than 390 volts. The capacitor is failing to hold the voltage and needs to be replaced.
Sharp LC... | Answered on Oct 29, 2017
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
Sharp LC... | Answered on Dec 16, 2016
Look for it at its bottom side [stand]
Sharp LC... | Answered on Sep 26, 2016
Here you can get solution of your question/problem.
https://support.roku.com/hc/en-ca/articles/209403268-Roku-TV-Introduction
Sharp LC... | Answered on Sep 17, 2016
Not on every model.
Sharp LC... | Answered on Sep 12, 2016
Sharp LC-37DB5U 37 in. HDTV LCD Television Logo
4 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
no picture
  • Televison & Video
