20 Most Recent Denon AVR-1513 3D A/V Receiver - 5.1 Channel Black Dolby TrueHD- DTS Questions & Answers
Denon 1513 overheating
It's possible that it might be a fault on the unit. One or more of the output devices could have a thermal problem. However at 80 watts it might be driving the amp a bit too hard, maximum for it seems to be between 75 and 110. Are all channels capable of delivering the 80 that is the question? If one is capable of only 75, then the answer will be that channel is the one overheating. If that is the case you would be better with an AVR that can deliver 100 watts on all channels. As for the choice go for what you can afford and look at the customer reviews closely. They are the best guide to a decent bit of kit.
11/3/2017 12:38:01 PM • Denon AVR-1513... • Answered on Nov 03, 2017
I need help on how to set up my receiver AVR 1513
The owners manual can be found at many sites on the internet if you google for Denon AVR 1513. One site is amazon.com. http://s3.amazonaws.com/szmanuals/d357e31200b1de2a76b2e5619ef9cdd8
7/7/2014 7:12:16 AM • Denon AVR-1513... • Answered on Jul 07, 2014
Denon X6700h has no power at all.
If there is a fuse, it will be on the power board, easy to spot, a glass cased fuse, or a small white ceramic fuse. Normally though, a 125,000 volts wrecks everything connected to power. https://www.google.com/search?q=Denon+X6700h+has+no+power ..
8/18/2023 6:18:18 PM • Denon Televison... • Answered on Aug 18, 2023
2answers
Denon 687 ,,,,red light is on then I push the power button and it blinks green and their stays green but no display at all nothing else lights up
Considering you have a standby light we know the hot side of the power board is working, next step is test the power on signal coming from the main board, it should be marked on the legend on the power board what pin is power on, will be marked PO_ ON PWR or something like that, you need at least 3 vdc there when you turn the set on, if it's missing replace the main board, if you see voltage replace the power board, easy simple fix with only one measurement, verses guessing what board is bad. Sorry you didn't get any other useful help, there are some posters on here giving non helpful generic help anyone would know to try
3/24/2023 12:56:49 PM • Denon Televison... • Answered on Mar 24, 2023
Completely clueless on setting up Denon 1709 AVR
Yes, you can still use the speakers even if they are not currently connected to a TV. To connect the speakers to your computer, you will need an audio cable with 3.5mm plugs on both ends. One end will plug into the headphone jack on your computer, and the other end will plug into the input on the speakers. Some speakers may also have RCA input, in which case you will need an RCA-to-3.5mm audio cable. If you have a newer computer with only a digital output (such as a USB-C port), you may need to use an audio interface or a digital-to-analog converter (DAC) to convert the digital signal to analog so you can plug it into your speakers. Once the speakers are connected to your computer, you can adjust the volume using the volume controls on your computer or the speakers themselves. It's important to note that your TV will not be able to use the speakers unless they are connected to it.
1/31/2023 8:30:48 PM • Denon Televison... • Answered on Jan 31, 2023
2answers
DENON AVR 3801, Wont Power on
Sorry not familiar with this brand TV
8/7/2022 7:02:07 AM • Denon Televison... • Answered on Aug 07, 2022
2answers
Replacement for Denon RC-229
You can buy the original remote control on eBay for $10.92. No need for a different brand.
7/3/2022 6:24:57 AM • Denon Televison... • Answered on Jul 03, 2022
My Denon remote has partially stopped working. I can still switch the TV on and off and mute the sound but can no longer change channels or select apps. The battery level is full. Any suggestions
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrohelponline.blogspot.com/
3/12/2021 1:15:31 PM • Denon Televison... • Answered on Mar 12, 2021
2answers
How to fix my Denon DBP-4010ud Blu-Ray Player
Appears to be a software problem. Unfortunately, some blu-ray players contain software that expires, requiring you to repurchase newer, more expensive software from the manufacturer in order to continue to play blu-ray discs. Check your software for the player. No freeware blu-ray software out there.
11/13/2019 2:09:51 AM • Denon Televison... • Answered on Nov 13, 2019
How to unlock denon bluray dbt1713ud?
You can use a USB stick for region A, B or C. (1, 2 of 4) On the USB stick there is one file named autoscript with the following : CLI(CLI_app.homemenu.set_bdreg 4). ,4 you can also use 1 or 2 this depends on the disired region. Just copy this with textprogram and name the file 'autoscript' T 1. Remove any discs from the drive of your player 2. Put the player into standby 3. Put the USB stick with the desired bluray region into the player 4. Turn on the player 5. Wait 5 seconds 6. Put the player into standby 7. Wait 10 seconds 8. Remove the USB stick 9. Unplug the mains cable 10. Unit should now be the region you have chosen for bluray Before you do any firmware update, return to Region B as it may lock the region.hen do the following:
8/23/2019 2:42:20 AM • Denon Televison... • Answered on Aug 23, 2019
Denon dvd player freezes in
sounds like its stoping during layer switch, if the player is old its needs to be cleaned. its best to clean it once every 20hrs or so. if you do not have a disk cleaner you should go buy one first. if the player is new return it and get the best dvd player you can buy for any amount the toshiba xde. this player is phenomenal, the best you will be amazed. no i dont work for toshiba but ever since they started making hd dvd players(i know they stopped)there players have become the best. trust me if you dont think so just return it. no harm done. if you want a blu-ray get ps3 I dont like them either but i have to admit after buying (for movies only)my third blu-ray player it is by far the best one. almost as good as the toshiba on standard dvd playback but not quite. good luck.
4/17/2019 8:28:31 AM • Denon Televison... • Answered on Apr 17, 2019
A DVD playing on my Denon 1805 froze. I usually can fast fwd past such problems, but ng. I replaced the disc and now it won't it load. I tried a 2nd DVD and it also won't load. What is my problem?
Verify that the disc turns, put it in the tray, observe the position, enter it, wait for the indication of "No Disc" and remove the disc, if it is in the same place, apparently, it would have problems in the disc engine Another way to check if the engine works, play an audio CD, if you read it, apparently the engine, it would not be the cause of the failure If I notice that I turn, I could have dirt problems in the lens of the reader, proceed to clean it with a cotton swab and if you do not know how to do it, contact a technical service Another option, it is possible that your reader is under power to read the DVD Verifique que el disco gire, p?ngalo en la bandeja, observe la posici?n, ingreselo, espere a la indicaci?n de "No Disc" y saque el disco, si esta en el mismo lugar, aparentemente , tendr?a problemas en el motor del disco Otra forma de chequear si el motor funciona, reproduzca un CD de audio, si lo lee, aparentemente el motor, no seria el causante de la falla Si observo que giro, podr?a tener problemas de suciedad en el lente del lector, proceda a limpiarlo con un hisopo de algod?n y si no sabe como hacerlo, dir?jase a un servicio t?cnico Otra opci?n, es posible que su lector esta bajo de potencia para leer los DVD
4/14/2019 11:52:36 PM • Denon Televison... • Answered on Apr 14, 2019
When I opened my Denon remote, it was full of glue. It was also dead. Should I remove the glue ? before cleaning. AVR -1610 remote RC-1120.
How do I reset my Denon remote? All the settings are restored to their defaults. Press and hold RC SETUP for more than 3 seconds. "SETUP" and indicator flashes twice on the remote control unit. Use to display "RESET" on the remote control unit and press ENTER
3/8/2019 8:50:57 PM • Denon Televison... • Answered on Mar 08, 2019
A denon AVR1505 and remote
If you have the Audyssey set up mic, plug it in and follow the on screen instructions. Or try installing the Denon AVR remote app.
12/26/2018 1:22:27 PM • Denon Televison... • Answered on Dec 26, 2018
Denon AVR-1513 3D A/V Receiver - 5.1 Channel Black Dolby TrueHD- DTS Logo
10 questions posted
Top Denon Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Televison & Video
Most Popular Question
denon 1513 overheating
  • Televison & Video
