20 Most Recent Casio Exilim EXZ1050 Digital Camera Questions & Answers
The battery holders can be fragile. You may have to attempt to repair rather than replace.
Casio Exilim... | Answered on Dec 31, 2017
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Casio Exilim... | Answered on Aug 16, 2011
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Casio Exilim... | Answered on Jul 31, 2011
Plaese download your driver here : http://exilim.casio.com/support.shtml
Regards
Casio Exilim... | Answered on Dec 17, 2010
it is a lens error and you can solve it by hitting the lens area with the soft tissues of your palm .. this worked for me..
Casio Exilim... | Answered on Sep 15, 2010
u will have to buy a new charger because casio doesn't make its camera with USB charging option. click on this link to buy a new charger.
Casio Exilim... | Answered on Sep 01, 2010
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Casio Exilim... | Answered on Aug 11, 2010
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
No offense, but you should have let someone who knew what they were doing replace it for you.
Casio Exilim... | Answered on Feb 19, 2010
Move the slide switch on the side of the card.
Casio Exilim... | Answered on Feb 09, 2010
in your menu you will be able to find a solution to this...it will be somewhere where the memory is stored....i could give you some help if you walk me through what is on your screen
Casio Exilim... | Answered on Dec 22, 2009
the unit is hanged. just hard reset it
Remove the battery for a minute a reinsert it again.and turn it ON.
this will reset the unit and it will start working properly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Casio Exilim... | Answered on Dec 12, 2009
The process only works one way...from the camera to the computer.
Casio Exilim... | Answered on Oct 12, 2009
Try the following:
1). Check batteries whether they are fully charged.
2). Check with Battery terminal are clean. You can clean them with a ear bud using some alcohol or spirit. Wipe the battery terminal with a clean dry cloth.
3). confirm that the memory car slot/battery cover is securly closed.
4). Reload the battery several times. This will also remove poor contact between camera and battery terminals.
5).Check battery are loaded in the correct direction.
If the probem persists, you might need to take it to the service center.
Casio Exilim... | Answered on Apr 22, 2009
From your description sounds like the lcd maybe going out?
Casio Exilim... | Answered on Mar 18, 2009
We discovered that the photos weren't corrupt on the camera, but were being corrupted when transferred to Picassa, during the transfer process. We transferred some test photos using a simple file copy operation and it worked out fine.
Casio Exilim... | Answered on Dec 29, 2008
It's probably a faulty shutter. Take a look at my blog post to a possible solution.
Casio Exilim... | Answered on Oct 03, 2008
Casio Exilim EXZ1050 Digital Camera Logo
33 questions posted
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
accidentally dropped casio
  • Cameras
