20 Most Recent
Syntax Olevia 432V 32 in. LCD Television Questions & Answers
Do i need to update my tv its 5 years old
No if tv is working fine then you do not need to upgrade. If you wish to see digital tv option will be to get a set box that plugs into tv. Provided tv has the rca red, yellow, white or svideo or scart connector
Cracked screen
A new panel is $400 (not including labor). A new 32" LCD is $299. You would have to get it repaired by the manufacturer, as those panels are only available in large quantities.
My syntax led tv sle3293md wont start
Fault to its main board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Blue screen on my syntax lcd t v
Try disconnecting unit from power source for several minutes.
Before re-connecting power hold power button for 5 seconds and I hope this resolves your problem.
Tv manual LT26HVX
If you are looking for the operators manual, that can usually be down loaded from the manufacturers web site.
If you are looking for a service manual, I use
www.servicemanuals.net , You have to register and there is a fee involved for each manual you order, but you can download the service/schematic manuals for immediate use. They have an extensive library, but not everything.
Olevia 432 missing screws
ok take the tv in to the home depot hardware store..go to the aisle where the hardware nuts/bolts/screws are..need to look either in the metric stuff and have a service person help you find the right size screws.. they carry them there..lowes does also but they are a bit more expensive..
