20 Most Recent
Sony VAIO VGN-FE660G Notebook Questions & Answers
I have changed my windows.
If you were to log on to sony's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies and
Driver
downloads
(if applicable)
as required.
The information is normally free of
charge.
I hope this helps.
1/5/2011 5:01:38 PM •
Sony VAIO...
Answered
on Jan 05, 2011
NECESITO LOS DRIVERS DE MI
Hi ngsis_rv ,
You can download all the Drivers and Software for the Sony VAIO VGN-FE660G
Computer model from the below link.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFE660G
Please go through the important notes and installation instructions with each Drivers/Software while installing it.
Hope this helps.
Good Luck!
Please post back if you have any questions or require any further assistance.
Thanks for using FixYa.
11/5/2010 3:28:36 AM •
Sony VAIO...
Answered
on Nov 05, 2010
I need a video card
The graphics cards are actually integrated onto the motherboard and are unfortunately not inter-changeable like desktops. Your next option would be to purchase a new/working motherboard. Good luck!
9/3/2010 2:34:54 AM •
Sony VAIO...
Answered
on Sep 03, 2010
My sony vgn 660g detects the wireless card but it
I would try pulling down a current install file from Sony's website along with a Diagnostic CD. But from what your describing it sounds like the internal wireless card is not working - contact your manu for warranty, and/or take it to a local pc shop and see if they can replace it.
9/3/2010 2:32:03 AM •
Sony VAIO...
Answered
on Sep 03, 2010
Usb ports!
I would suggest either contacting your manufacture for a diagnostic disk. It is possible the ports are failing. If all tests do come back ok and detects no problems with the ports, I would then recommend uninstalling any programs that would use the ports for example KVM switch software. If that does not work (and again the diag came back ok) I would reinstall your windows.
9/3/2010 2:29:15 AM •
Sony VAIO...
Answered
on Sep 03, 2010
Dvd drive isnt working
What happens when you insert a DVD/CD? If inserting one immediately locks the laptop, and you have already tried uninstalled and reinstalling the drive, its time to purchase another DVD drive for your laptop.
9/3/2010 2:23:55 AM •
Sony VAIO...
Answered
on Sep 03, 2010
I was working on my laptop the other night and it
Have you tried plugging it in power minus the battery then try to switch on. when battery is inserted, and power code plugged in, do you get any leds that atleast indicate that power is entering?
5/18/2010 10:44:50 PM •
Sony VAIO...
Answered
on May 18, 2010
I only have a blinking cursor on boot, why is
Your memory is dump or dirt, please clean up your memory and try to put it again. Please clean it with an eraser. If the problem still exist please try to connect properly the hard disk.
1/31/2010 3:44:26 AM •
Sony VAIO...
Answered
on Jan 31, 2010
"Error loading operating system" message
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
4/9/2009 9:37:26 AM •
Sony VAIO...
Answered
on Apr 09, 2009
Lost second restore disk
i would think that best buy should be held resopsible for this if infact they lost the cd iff not the manufacture of the computer will be able to get you the cd that you need just call the tech support ok and they will ask you for the serial number on the computer and the service tag ok please keep me posted on this best regards mike
8/26/2008 12:51:37 PM •
Sony VAIO...
Answered
on Aug 26, 2008
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
