20 Most Recent
LG NB3510A 2.1 Sound Bar with Subwoofer - Home Theater Systems Questions & Answers
How to connect sound bar to 2011 smart tv
If your soundbar has bluetooth technology in it, turn it to the input of "Bluetooth" or "BT". In your TV's smart menu, you should be able to find bluetooth settings, and be able to find the soundbar from there. If you are looking to connect it by a cable, you will have to connect a digital optical cable into the back of the TV, and run it down into the soundbar to receive sound out of it.
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
